10-04-2012, 17:48 | #16 (permalink) |
Junior Member Join Date: May 2012
Member: 1759995 Status: Offline Thanks Meter: 0 | Resetting IMEI... Connecting to phone UART... Using Advanced MSL... Bypasing Security... Operation failed! having this problem just phurchased the nspro box updated to the latset version asknig for imei and serial. i normall use z3x never asked for serial and guessed most imei numbers this is different could andone help me solve this problem thanks |
10-04-2012, 17:56 | #17 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
2. Root the phone using I9300 Root file from support area. 3. Select I9300 Rooted on NsPro then write the IMEI and S/N number you need. Last edited by Elco; 10-04-2012 at 18:09. | |
10-04-2012, 18:02 | #18 (permalink) |
Member: 1759995 Status: Offline Thanks Meter: 0 | ijust followed these instructions (( 1 ) Download Peach File I9300 IN Rar File ( 2 ) Extract File (3 ) Open folder In Side ( 1 ) I9300 patch ( 2 ) Odin3 v3.04 In Folder (4 ) Open Odin3 v3.04 and Click On Pda Teb And selectI9300 patch ( 5 ) Put Phone In Download Mode Volume Down+Home+power Phone Say Continue Press Volume Up Phone In Download Mode N connect with Pc And Sat-up driver N After Click start button On Odin Pach File done After Go To Phone sating n click USB DEBUGGING connect Via Usb with Pc And Sat-up driver after Open Ns pro Click Imei Teb N Repair Imei ns pro restart Phone And After Use Box cable S7070 And connect Phone with Box) imei is now null null |
10-04-2012, 18:11 | #19 (permalink) | |
IMEI NULL/NULL indicate that EFS partition was damaged or the Modem core cant start on that phone. Contact me by yahoo messenger to give me more info about that phone and exactly how it got damaged then i will help you to repair it. | |
10-04-2012, 18:16 | #20 (permalink) |
Member: 1759995 Status: Offline Thanks Meter: 0 | i will contact you soon thank ypu for you help now i have the 004999010640000/03 imei coming up i rooted it also and chose i9300 rooted from the menu it will be i contac you tahnk you |
10-08-2012, 15:09 | #23 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1791259 Status: Offline Thanks Meter: 1 | anyone help please.... i do not have this box... here in australia people do not have it... i need to repair my i9300 imei .... can it be done without this box or any other hardware? (if i can get someone do it and send his ns_data.bin ?) |
10-10-2012, 09:38 | #24 (permalink) |
Insane Poster Join Date: May 2009
Member: 1026404 Status: Offline Thanks Meter: 5 | What the problem? My phone imei 00499901.... I rooted 9300root.tar and use 9300 patch imei repaire, but nothing! Preparing Phone... Resetting IMEI... Connecting to phone UART... Using Advanced MSL... Bypasing Security... Setting Serial Number... Writing IMEI... Resetting Phone... Operation successfully completed |
10-10-2012, 10:48 | #25 (permalink) | |
Just root the phone then select I9300 Rooted on NsPro and write IMEI | |
The Following User Says Thank You to Elco For This Useful Post: |
10-10-2012, 21:47 | #28 (permalink) | |
Junior Member Join Date: Oct 2009
Member: 1148536 Status: Offline Thanks Meter: 3 | Quote:
thanks | |
