01-25-2005, 09:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | How to solve 9500 PDA (ADL) flashing problems This probelms is also confirmed by Nokia in Service Bulletin 013, released on 24-January-2005. This Service Bulletin can be find here: http://www.phoenixblackbox.com/ra2-013.pdf Here is 2 solutions how to solve this PDA flashing problems. Solution 1 (thanks to Mind):
Solution 2 (as Nokia say in SB-013.PDF):
Please try both of this solutions and report good or wrong working, and what PC, Windows, PCI USB card you have used. Also all written here is valid for Nokia 9300 too. Best regards, Zulea Last edited by zulea; 01-25-2005 at 09:55. |
01-29-2005, 10:30 | #2 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Egypt Age: 44
Member: 51609 Status: Offline Thanks Meter: 6 | successfuly flashing 9500 i have 9500 that freez on startup so try to flash it useing win xp sp1 intel pentium 3 processor 799 MHz 256 mb ram normal usb that built in with motherbord install phoenix_service_sw_2004_39_7_70-Nov11-002922 thin instal phoenix_service_sw_2004_46_4_75 thin instal phoenix_service_sw_2004_46_5_76_upd thin install again DRV_FLS4_204 thin instal again flash_update_03_19_000 use both cable fbus and dku-2 whin try first to flash the phone got error mcu did not ack so remove 3.3k resistor from that china cable and connect bsi line directly without any resistor so flashing work ok for adl avalon driver i use Nokia_Conn_Cable_Driver_137_eng.exe and in same pc i install ADL drivers for 6630 and flash one 6630 befor start flashing 9500 so thir is no problem if we install driver for 6630 and 9500 in same pc it work ok with me in same pc for both 6630 and 9500 flashing Reading data from phone Reading phone information Reading product type Reading HW version Reading product code Reading PSN Get flash file names Reading IMEI Reading flash settings from file(s) Detecting FLS4 FLS4 detected FLS Licenses remaining 1000 Starting flash... Detecting FLS4 FLS4 detected Initializing prommer Detecting flash device... Detecting FLS4 FLS4 detected FLS4 found Flashing image ADL(usb) Entering ADL Flash FLS-X Initialization done Licences remaining: 1000 Erasing Flash... Opening USB connection USB connection created succesfully for APE flashing ADL->Ape flashing Started ADL->AdlServer: Phone info requested succesfully ADL->Flash manufacturer : Toshiba ADL->Flash type: 0007, Revision1: 0000, Revision2: 0000 ADL->Using AdlLoader file: D:\Program Files\Nokia\Phoenix\flash\OMAP1510_TOSHIBAMDOCG3_7 .adl Erasing: 5% ADL->Waiting connection to ADL Loader ADL->AdlLoader: Communication verified Erasing: 10% ADL->Reflash command sent successfully. Options: 4 ADL->Flash file sending started. Erasing: 20% Erasing: 25% Erasing: 30% Erasing: 35% Erasing: 45% ADL->Programming: 10% Erasing: 50% Erasing: 55% Erasing: 60% Erasing: 70% ADL->Programming: 20% Erasing: 75% Erasing: 80% Erasing: 85% Erasing: 95% Erasing: 100% Time Taken to Erase 38.265 Start programming flash memory... Programming: 5% ADL->Programming: 30% Programming: 10% Programming: 15% Programming: 20% Programming: 25% Programming: 30% Programming: 35% Programming: 40% Programming: 45% Programming: 50% Programming: 55% Programming: 60% ADL->Programming: 40% Programming: 65% Programming: 70% Programming: 75% Programming: 80% Programming: 85% Programming: 90% Programming: 95% Programming: 100% ADL->Programming: 50% ADL->Programming: 60% ADL->Programming: 70% ADL->Programming: 80% ADL->Programming: 90% ADL->Programming: 100% ADL->Image code sent successfully ADL->Reflash command sent successfully. Options: 4 ADL->Flash file sending started. ADL->Programming: 10% ADL->Programming: 20% ADL->Programming: 30% ADL->Programming: 40% ADL->Programming: 50% ADL->Programming: 60% ADL->Programming: 70% ADL->Programming: 80% ADL->Programming: 90% ADL->Programming: 100% ADL->Image code sent successfully Programming done!!! Time Taken to Flash 205.355 Total Blocks ca.148 After MCU SW flashing delay2000ms Flashing done Reading data from phone Loading data to phone. Please wait. Product Profile OK Flashing succeeded. Detecting FLS4 FLS4 detected FLS Licenses remaining 1000 Polling product Last edited by KARAMAT; 01-29-2005 at 10:43. |
02-05-2005, 12:30 | #5 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Every time this problem: Reading data from phone Reading flash settings from file(s) FLS Licenses remaining 1000 Starting flash... Detecting FLS4 FLS4 detected Initializing prommer Detecting flash device... Detecting FLS4 FLS4 detected FLS4 found Flashing image ADL(usb) Entering ADL Flash FLS-X Initialization done Licences remaining: 1000 Error! MCU did not boot Opening USB connection Trying to open USB connection, please wait. Sleeping 2 seconds Count=6 Trying to open USB connection, please wait. Sleeping 2 seconds Count=5 Trying to open USB connection, please wait. Sleeping 2 seconds Count=4 Trying to open USB connection, please wait. Sleeping 2 seconds Count=3 Trying to open USB connection, please wait. Sleeping 2 seconds Count=2 Trying to open USB connection, please wait. Timeout for opening USB connection for APE ADL->ADL FLASHING FAILED !!! Flashing failed. |
02-07-2005, 12:11 | #6 (permalink) |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | I have resolve the resistor from cable 3.3,,, after that flashing starts.... and the phone dead. No I try to flash agine and: Reading data from phone Reading flash settings from file(s) FLS Licenses remaining 1000 Starting flash... Detecting FLS4 FLS4 detected Initializing prommer Detecting flash device... Detecting FLS4 FLS4 detected FLS4 found Flashing image ADL(usb) Entering ADL Flash FLS-X Initialization done Licences remaining: 1000 Error! Command Failed Opening USB connection USB connection created succesfully for APE flashing ADL->Ape flashing Started ADL->AdlServer: Phone info requested succesfully ADL->Flash manufacturer : Toshiba ADL->Flash type: 0007, Revision1: 0000, Revision2: 0000 ADL->Using AdlLoader file: C:\Program Files\Nokia\Phoenix\flash\OMAP1510_TOSHIBAMDOCG3_7 .adl ADL->Waiting connection to ADL Loader ADL->AdlLoader: Communication verified ADL->Reflash command sent successfully. Options: 4 ADL->Flash file sending started. ADL->Programming: 10% ADL->Programming: 20% ADL->Programming: 30% ADL->Programming: 40% ADL->Programming: 50% ADL->Programming: 60% ADL->Programming: 70% ADL->Programming: 80% ADL->Programming: 90% ADL->Programming: 100% ADL->Image code sent successfully ADL->Reflash command sent successfully. Options: 4 ADL->Flash file sending started. ADL->Programming: 10% ADL->Programming: 30% ADL->Programming: 50% ADL->Programming: 60% ADL->Programming: 80% ADL->Programming: 100% ADL->Image code sent successfully After MCU SW flashing delay2000ms Flashing done Reading data from phone Reading data from phone Reading data from phone Reading data from phone Reading data from phone Reading data from phone Reading data from phone Reading data from phone Flashing failed. |
02-07-2005, 13:10 | #7 (permalink) |
Member: 51609 Status: Offline Thanks Meter: 6 | try to flash the phone again but this time use clean win and install phoenix service sw start with v 2004_39_7_70 to v sw_2004_46_5_76_upd and install fia and fls driver and and dku-2 driver and thin start flashing whin the program ask u for ape driver install it from dku-2 files and use last flash file v RA-2 SW 04 51 00 i hope this help u and go with successfull flashing and working phone ps. whin u strat flash the phone set ur active connection to fbus not to usb ur last try to flash the phone it only flash ape part and don't flash mcu part so u must have a dead phone |
02-07-2005, 15:16 | #9 (permalink) |
Freak Poster Join Date: Aug 2003
Member: 37821 Status: Offline Thanks Meter: 1 | MCU failure Reading data from phone Reading phone information No phone detected! Reading flash settings from file(s) Detecting FLS4 FLS4 detected FLS Licenses remaining 1000 Starting flash... Detecting FLS4 FLS4 detected Initializing prommer Detecting flash device... Detecting FLS4 FLS4 detected FLS4 found Flashing image ADL(usb) Entering ADL Flash FLS-X Initialization done Licences remaining: 1000 Opening USB connection USB connection created succesfully for APE flashing ADL->Ape flashing Started ADL->AdlServer: Phone info requested succesfully ADL->Flash manufacturer : Toshiba ADL->Flash type: 0007, Revision1: 0000, Revision2: 0000 ADL->Using AdlLoader file: C:\Program Files\Nokia\Phoenix\flash\OMAP1510_TOSHIBAMDOCG3_7 .adl ADL->Waiting connection to ADL Loader Erasing Flash... ADL->AdlLoader: Communication verified ADL->Reflash command sent successfully. Options: 4 ADL->Flash file sending started. Erasing: 5% Erasing: 10% Erasing: 20% Erasing: 25% ADL->Programming: 10% Erasing: 30% Erasing: 35% Erasing: 45% Erasing: 50% ADL->Programming: 20% Erasing: 55% Erasing: 60% Erasing: 70% Erasing: 75% ADL->Programming: 30% Erasing: 80% Erasing: 85% Erasing: 95% Erasing: 100% Time Taken to Erase 41.875 Start programming flash memory... Programming: 5% Programming: 10% Programming: 15% Programming: 20% ADL->Programming: 40% Programming: 25% Programming: 30% Programming: 35% Programming: 40% Programming: 45% Programming: 50% Programming: 55% Programming: 60% Programming: 65% Programming: 70% Programming: 75% ADL->Programming: 50% Programming: 80% Programming: 85% Programming: 90% Programming: 95% Programming: 100% ADL->Programming: 60% ADL->Programming: 70% ADL->Programming: 80% ADL->Programming: 90% ADL->Programming: 100% ADL->Image code sent successfully Error! MCU failure ADL->MTI call failed, check connections!! Phone did not answered the following message: ADL_LDR_REFLASH_REQ ADL-> 80042007 is Mti timeout which means that no response for this message from the phone ADL->AdlLoader: Reflash request sending failed, resending ADL->MTI call failed, check connections!! Phone did not answered the following message: ADL_LDR_REFLASH_REQ ADL-> 80042007 is Mti timeout which means that no response for this message from the phone ADL->AdlLoader: Reflash request sending failed, resending ADL->MTI call failed, check connections!! Phone did not answered the following message: ADL_LDR_REFLASH_REQ ADL-> 80042007 is Mti timeout which means that no response for this message from the phone ADL->APE Flashing failed ADL->ADL FLASHING FAILED !!! Flashing failed. |
02-07-2005, 15:41 | #10 (permalink) | |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
02-07-2005, 23:11 | #13 (permalink) |
Member: 51609 Status: Offline Thanks Meter: 6 | @ GSMtricks about 9500 last flash file u can find it in twister support area maby soon zulea will upload it to pbb support area or try to do that 20 post to get the flah from i-phone @ emad1999 ur wellcome my brother |
How to solve Nokia E55 memory full problem after flash? | svchost | Universalbox | 7 | 08-15-2010 12:02 |
Sagem My220x dead after flash, how to solve this problem? | svchost | FuriousGold | 3 | 02-02-2010 13:58 |
