10-09-2005, 17:50 | #64 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Somewhere in the World Age: 54
Member: 9848 Status: Offline Thanks Meter: 144 | to flash 9500 use windows 2000 only switch on 9500 and let windows recognize and install several drivers - therefor install newest ca-53/dku-2 drivers first after that start phoenix and set 9500 in testmode, phone must be connected during f-bus, not usb but usb cable still must be between pc and 9500, then go to sw update and start flashing. during flashing windows installs two additional usb drivers (adl) and flashing completes |
10-25-2005, 01:11 | #65 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 229 | 7.5V 1.2 A, 98 phoenix, XP SP2 home, athlom 64 Reading data from phone Reading flash settings from file(s) FLS Licenses remaining 1000 Setting factory defaults Starting flash... Initializing FLS device init status OK Initializing prommer Initializing FLS device init status OK Flashing image FLS-X Ok... Erasing Flash... Erasing Flash......1% Erasing Flash......4% Erasing Flash......7% Erasing Flash......10% Opening USB connection Erasing Flash......13% Cmt->Adl Procedures Started Cmt->AdlServer: Communication verified Cmt->AdlServer: Phone info requested succesfully Cmt->Flash manufacturer : Toshiba Cmt->Flash type: 0007, Revision1: 0000, Revision2: 0000 Erasing Flash......16% Cmt->Using AdlLoader file: C:\Program Files\Nokia\Phoenix\flash\OMAP1510_TOSHIBAMDOCG3_7 .adl Cmt->C:\Program Files\Nokia\Phoenix\flash\OMAP1510_TOSHIBAMDOCG3_7 .adl Cmt->C:\Program Files\Nokia\Phoenix\products\RA-2\RA2n5221.c01 Cmt->C:\Program Files\Nokia\Phoenix\products\RA-2\RA2n5221.l16 Cmt->C:\Program Files\Nokia\Phoenix\products\RA-2\RA2n5221.u16 Cmt->AdlLoader loading: C:\Program Files\Nokia\Phoenix\flash\OMAP1510_TOSHIBAMDOCG3_7 .adl Cmt->Flash file code succesfully read from file Cmt->AdlServer: AdlLoader code reflash request sent succesfully Cmt->Sending Loader code: 8% Cmt->Sending Loader code: 16% Cmt->Sending Loader code: 25% Cmt->Sending Loader code: 33% Cmt->Sending Loader code: 41% Cmt->Sending Loader code: 50% Erasing Flash......19% Cmt->Sending Loader code: 58% Cmt->Sending Loader code: 66% Cmt->Sending Loader code: 75% Cmt->Sending Loader code: 83% Cmt->Sending Loader code: 91% Cmt->Sending Loader code: 100% Cmt->AdlServer: AdlLoader code succesfully sent to phone Cmt->Starting Adl Loader Cmt->AdlServer: Reboot command sent Cmt->Adl Loader Started Erasing Flash......22% Cmt->Waiting connection to ADL Loader Cmt->AdlLoader: Communication verified Cmt->Erasing of file 1 started Cmt->Erasing of file 1 finished Cmt->Programming of file 1 started Erasing Flash......25% Erasing Flash......27% Erasing Flash......30% Cmt->AdlLoader: Reflash command sent successfully. Options: 4 Cmt->Adl Loader: Starting to send the image file Erasing Flash......33% Erasing Flash......36% Erasing Flash......39% Erasing Flash......42% Erasing Flash......45% Erasing Flash......48% Erasing Flash......51% Erasing Flash......54% Erasing Flash......57% Erasing Flash......60% Erasing Flash......63% Cmt->Programming: 10% Erasing Flash......66% Erasing Flash......69% Erasing Flash......72% Erasing Flash......75% Erasing Flash......77% Erasing Flash......80% Erasing Flash......83% Erasing Flash......85% Erasing Flash......88% Erasing Flash......91% Erasing Flash......92% Erasing Flash......95% Cmt->Programming: 20% Erasing Flash......98% Erasing Flash......100% Time Taken to Erase 36.500 Start programming flash memory... Programming Image file...0% Programming Image file...1% Programming Image file...2% Programming Image file...3% Programming Image file...4% Programming Image file...5% Programming Image file...6% Programming Image file...7% Programming Image file...8% Programming Image file...9% Programming Image file...10% Programming Image file...11% Programming Image file...12% Programming Image file...13% Programming Image file...14% Programming Image file...15% Programming Image file...16% Programming Image file...17% Programming Image file...18% Programming Image file...19% Programming Image file...20% Programming Image file...21% Programming Image file...22% Programming Image file...23% Programming Image file...24% Programming Image file...25% Programming Image file...26% Programming Image file...27% Programming Image file...28% Programming Image file...29% Programming Image file...30% Programming Image file...31% Programming Image file...32% Programming Image file...33% Programming Image file...34% Programming Image file...35% Programming Image file...36% Programming Image file...37% Cmt->Programming: 30% Programming Image file...38% Programming Image file...39% Programming Image file...40% Programming Image file...41% Programming Image file...42% Programming Image file...43% Programming Image file...44% Programming Image file...45% Programming Image file...46% Programming Image file...47% Programming Image file...48% Programming Image file...49% Programming Image file...50% Programming Image file...51% Programming Image file...52% Programming Image file...53% Programming Image file...54% Programming Image file...55% Programming Image file...56% Programming Image file...57% Programming Image file...58% Programming Image file...59% Programming Image file...60% Programming Image file...61% Programming Image file...62% Programming Image file...63% Programming Image file...64% Programming Image file...65% Programming Image file...66% Programming Image file...67% Programming Image file...68% Programming Image file...69% Programming Image file...70% Programming Image file...71% Programming Image file...72% Programming Image file...73% Programming Image file...74% Programming Image file...75% Programming Image file...76% Programming Image file...77% Programming Image file...78% Programming Image file...79% Programming Image file...80% Programming Image file...81% Programming Image file...82% Programming Image file...83% Programming Image file...84% Programming Image file...85% Programming Image file...86% Programming Image file...87% Programming Image file...88% Cmt->Programming: 40% Programming Image file...89% Programming Image file...90% Programming Image file...91% Programming Image file...92% Programming Image file...93% Programming Image file...94% Programming Image file...95% Programming Image file...96% Programming Image file...97% Programming Image file...98% Programming Image file...99% Programming Image file...100% Cmt->Programming: 50% Cmt->Programming: 60% Cmt->Programming: 70% Cmt->Programming: 80% Cmt->Programming: 90% Cmt->Programming: 100% Cmt->AdlLoader: File sent successfully Cmt->Programming of file 1 finished Cmt->Erasing of file 2 started Cmt->Erasing of file 2 finished Cmt->Programming of file 2 started Cmt->AdlLoader: Reflash command sent successfully. Options: 4 Cmt->Adl Loader: Starting to send the image file Cmt->Programming: 30% Cmt->Programming: 40% Cmt->Programming: 50% Cmt->Programming: 80% Cmt->Programming: 90% Cmt->Programming: 100% Cmt->AdlLoader: File sent successfully Cmt->Programming of file 2 finished Cmt->Erasing of file 3 started Cmt->Erasing of file 3 finished Cmt->Programming of file 3 started Cmt->AdlLoader: Reflash command sent successfully. Options: 4 Cmt->Adl Loader: Starting to send the image file Cmt->Programming: 100% Cmt->AdlLoader: File sent successfully Cmt->Programming of file 3 finished Cmt->Sending reboot command. Cmt->Phone rebooted. Programming done!!! Time Taken to Flash 134.532 Total Blocks ca.149 After MCU SW flashing delay2000ms Flashing done Reading data from phone Setting factory defaults Loading data to phone. Please wait. Product Profile OK Flashing succeeded. Initializing f*l*s device init status OK f*l*s Licenses remaining 1000 Polling product Thank you Zulea |
How to solve Nokia E55 memory full problem after flash? | svchost | Universalbox | 7 | 08-15-2010 12:02 |
Sagem My220x dead after flash, how to solve this problem? | svchost | FuriousGold | 3 | 02-02-2010 13:58 |
