04-23-2005, 04:33 | #1 (permalink) |
Insane Poster Join Date: Oct 2003 Location: china-beijing Age: 49
Member: 41047 Status: Offline Thanks Meter: 0 | MY PBB dongle is bad. when I reinstall the program,it spear: installation can not continue without a dongle,insert Nokia dongle and click Retry to re-detect the ndongle or Canle to exit the installation. But yesterday my dongle is good. after I used the Blackbox tool to online update,my dongle is bad. PKD Serial number: PKD Serial number length: 05 FLS Serial number: 262629 FLS Max counter: 1000 FLS counter: 14215287 PBB firmware version: 08 can not startup the soft of Nokia(PBB). but can startup the soft of NEC.for NEC is good. please help me. |
04-23-2005, 06:44 | #2 (permalink) | |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | Quote:
So please try to force update again and set your PKD-1 serial number to 6 digit.Then try to install phoenix again or switch your PBB to FLS-4S mode before installing SW Hope that can help you out Best regards | |
04-23-2005, 06:56 | #3 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
B.R., Raskal | |
04-23-2005, 07:23 | #4 (permalink) |
Member: 41047 Status: Offline Thanks Meter: 0 | thanks you reply. 1,nobady change my LPT setting. 2.I have already force update manytimes,but the problem is still. 3.How to set my PKD-1 serial number to 6 digit???? 4.my PDK sn aways :5_____. 5.when I force update.read corent setting:PKD Serial number: PKD Serial number length: 05 |
04-23-2005, 07:29 | #5 (permalink) | |
B.R., Raskal | |
04-23-2005, 07:53 | #6 (permalink) |
Member: 41047 Status: Offline Thanks Meter: 0 | 1.I changed my pkd serial to any number,(PDK SN Length:6digits sn) then click the button:write PDK sn , it spear:PKD SN write OK. But I click the:read corent setting it spear: PKD Serial number , PKD Serial number length: 05 FLS Serial number: 262629 FLS Max counter: 1000 FLS counter: 7929211 PBB firmware version: 08 |
04-23-2005, 12:59 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Just update with BOTH Force update and EEPROM defaults and NOT USE any LPT cable extension when you make update. Also check your power adapetr, it must be 7.5 volts. Best regards, Zulea |
04-23-2005, 13:09 | #8 (permalink) |
Member: 41047 Status: Offline Thanks Meter: 0 | 1.I have already force update manytimes,but the problem is still. 2.I did not used the any LPT cable extension . 3.power adapetr is good. yesterday ,I update my dongle online,when 40%,it stop,then I update it again, today ,I can not uesd it in NOKIA. but in NEC,the soft can work. |
04-23-2005, 13:40 | #9 (permalink) |
Freak Poster Join Date: Mar 2003 Location: FRANCE Age: 54
Member: 24179 Status: Offline Thanks Meter: 0 | Hello sir ZL a still have same problem For My two pbb , canno't use is for Nokia , But can unlock nec also alcatel and unlock Nokia , but Whene try to flash some phone , alwyas errore Pls try to solve My problem Bs regards FATI |
04-23-2005, 13:43 | #10 (permalink) | |
Member: 5325 Status: Offline Thanks Meter: 8,448 | Quote:
Best regards, Zulea | |
04-23-2005, 13:44 | #11 (permalink) | |
04-23-2005, 15:08 | #12 (permalink) |
Member: 41047 Status: Offline Thanks Meter: 0 | if the PBB's have some hardware problems. can I repair it by myself, for example, change some IC? reflash the eeprom? because MY reseller saied: no stockpile lately. |
04-23-2005, 17:20 | #13 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 58
Member: 133218 Status: Offline Thanks Meter: 0 | why guys here all refusing idea sending the items to resellers. i think it is best way to solve all problem. pbb is international and have resellers mostly all over the world. zuela did nice job for that. so relax and contact resellers always. am i right |
04-24-2005, 01:07 | #14 (permalink) | |
05-10-2005, 18:29 | #15 (permalink) |
No Life Poster Join Date: Apr 2004 Location: india Age: 47
Member: 62016 Status: Offline Thanks Meter: 48 | i am also having same problame in pbb PKD Serial number how sole the problame [email protected] |
My Thunderstorm Dongle Is Cut ,how Can I Repair It ??? | Eagle7 | ThunderStorm Box | 3 | 04-01-2006 15:42 |
MY PBB dongle is bad. | zhangyong7284 | Phoenix Black Box | 3 | 04-23-2005 18:24 |
MY UST dongle is DEAD! what to do VAHID??? | AE177 | UST Pro II | 4 | 10-18-2004 19:08 |
My Terminator Dongle Is Broken! | E&D | DIV | 0 | 06-08-2004 14:33 |
