05-30-2011, 18:49 | #33 (permalink) |
No Life Poster Join Date: Dec 2008 Location: bangladesh
Member: 926902 Status: Offline Sonork: 100.1655575 Thanks Meter: 517 | i know infinity always good work all time. hard work for me but wait wait...................................but not give us best solution spd tool now this time maximum mobile have spd cpu so i need big and proper spd flash solution |
05-31-2011, 00:06 | #37 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Philippines
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | 6253 Nor COM233 [Serial2] selected module v3.31 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A02:8A00 status: 03 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AB error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 12 sec Remove/Install battery now ! 6253 nand COM233 [Serial2] selected module v3.31 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A02:8A00 status: 03 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AB error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 17 sec Remove/Install battery now ! COM233 [Serial2] selected module v3.31 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A02:8A00 status: 03 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AB error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 17 sec Remove/Install battery now ! :-) |
05-31-2011, 08:11 | #38 (permalink) |
Insane Poster Join Date: Feb 2008 Location: India
Member: 696370 Status: Offline Thanks Meter: 27 | pls reply me infinity teams... lot of thanks for u great job... keep it up i would like to wish for ur all updates infinity teams. when you ur come to spreadtrum cpu's ?.... u don't mistake me ... all china phone first formatting and ime's in infinity box but now still many more types of china phone box wil come but ur the first one in the world i know.... so.,, why ??? |
06-02-2011, 16:41 | #43 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Madagascar
Member: 207280 Status: Offline Thanks Meter: 15 | Very good update Hi my brother! Very good update but how about the module Pana01 (infineon ZTE S318, S312+, S309, etc....?) We wait for this. Thanks Josh Last edited by InfinityHelp; 06-06-2011 at 08:20. |
06-06-2011, 08:21 | #44 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
hello! which phone do you try to boot? | |
06-08-2011, 04:49 | #45 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | COM5 [VCP0] selected module v3.31 Device: Autodetect 6253 NOR Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (460800)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: L5BMM02.9.52.1.6T11M1011_M700 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: JWT_Z120B_002_PCB01_GPRS_MT6253_S00.L5BMM02_9_52_1 _6T11M1011_M700.BIN project-id: L5BMM02.9.52.1.6T11M1011_M700, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\infinitybox\ChineseMiracle\JWT_Z120B_002_PCB01_ GPRS_MT6253_S00.L5BMM02_9_52_1_6T11M1011_M700__ful lflash_20110606-195048.B0M.bin Disconnect... done Finished, time used: 11 min 20 sec Remove/Install battery now ! |
Need 3210 5.31 software without opening phone, can exchange for: | igor_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-2000 13:38 |
solution for all 5110 ver 5.28 and 3210 ver 5.31 for exchange | sebastijan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-2000 20:47 |
solution for all 5110 ver 5.28 and 3210 ver 5.31 for exchange | sebastijan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-21-2000 09:21 |
2 FREE NOKIA SP SIM CARDS TO RELEASE FOR INFORMATION WE NEED | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-25-1999 03:34 |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
