09-06-2008, 14:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | Account suspended during activating pinfinder Pin-Finder Adapter detected !----------Process started:5:04:51 AM---------- Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: ********, Firmware: 0110.02 Authenticating on server... Authentication successfull. Checking DongleManager version... Your DongleManager is up-to-date. Checking Dongle Identification... Dongle Identification checked. Activating module... Module-04 S/N: 00D0D56D11B93165018BC0B7******** Module check error: Server reported error:[0043] Module S/N structure is incorrect. Contact to [email protected] ----------Process started:5:05:22 AM---------- Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: ********, Firmware: 0110.02 Authenticating on server... Authentication stage error: Server reported error:[0006] Your account is suspended: read previous error messages carefully and contact to [email protected] ==== log opened: [9/6/2008 5:05:40 AM] ==== Application: D:\flashes\Infinity Box\NEWUPDAT\DongleManager.exe Dongle Manager [Infinity Box] v1.25 Initializing Pin-Finder Adapter... searching adapter at COM1... too many retries can't find adapter searching adapter at COM1... too many retries can't find adapter searching adapter at COM4... too many retries can't find adapter searching adapter at COM28... too many retries can't find adapter searching adapter at COM19... adapter found, version: 2000 Serial No: 00D0D56D11B93165018BC0B7******** done Pin-Finder Adapter detected !----------Process started:5:06:27 AM---------- Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: ********, Firmware: 0110.02 Authenticating on server... Authentication stage error: Server reported error:[0006] Your account is suspended: read previous error messages carefully and contact to [email protected] ----------Process started:5:07:38 AM---------- Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: ********, Firmware: 0110.02 Authenticating on server... Authentication stage error: Server reported error:[0006] Your account is suspended: read previous error messages carefully and contact to [email protected] thanks BR. |
09-06-2008, 14:20 | #2 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Quote:
Must be Problem with Pinfinder Adopter!!!!!!!!!!!! Regards | |
09-06-2008, 16:55 | #5 (permalink) |
Member: 268415 Status: Offline Thanks Meter: 57 | nothing wrong with the reseller. i think some thing is wrong with the update server lots of guy's had this problem. thanks for the help. just waiting for the support's reply. Best regards. |
09-07-2008, 23:29 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | There is nothing wrong with reseller... There is nothing wrong with PinFinder... The only wrong thing is: advice ignorance Code: [email protected] |
09-08-2008, 09:50 | #7 (permalink) |
Member: 268415 Status: Offline Thanks Meter: 57 | im not a beginner i did same as it was in the tuturiol. i think u haven't seen the log. serial number structure is incorrect. i've send the email on the given address. Module check error: Server reported error:[0043] Module S/N structure is incorrect. Contact to [email protected] thanks |
09-09-2008, 15:10 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | We are checking logs very carefully every time and we try to give so good advices as possible. As you can see many problem can be solved fast just by advices given to you by DongleManager |
10-23-2008, 03:36 | #10 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Infinity Team, What is that mean!!! unfortunately, this pinfinder has damaged serial number and can not be registered in our system. Please conact your reseller and exchange it under warranty conditions. |
10-23-2008, 13:27 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, tell me what is not clear with given explanation. We ask you to contact to your reseller to replace PinFinder PCB. Also, if it\'s hard to make replacement via reseller you can contact to reseller, show him discussion about your PinFinder and ask reseller to contact to our support person via mail: [email protected] |
10-30-2008, 10:35 | #12 (permalink) |
Member: 268415 Status: Offline Thanks Meter: 57 | i had the same problem. i returned the box to the reseller that box wasn't working. there were no power in the power connectors. now i got the new 1 Infinity APF box plus and it works like charm. thanks BR. |
Account Suspended | BadUnlockers | Infinity-Box | 3 | 12-18-2008 18:42 |
my account suspended "because try to update more than 100 times" ?? | utuh | Infinity-Box | 13 | 11-02-2008 19:20 |
account suspend | tlnadar | Board, Server and Login Problems/Support | 0 | 10-07-2008 13:36 |
