10-31-2008, 16:29 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | After flash set white light Hexing25_gemini_pcb01_gprs_mt6225_s00.maui_gemini_ w08_12_52.bin |
10-31-2008, 21:46 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! many same looking chinese sets are different inside. same happend to you i guess. find in operation.log first operation which you did and check for exact original version name |
11-02-2008, 09:12 | #3 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | ==== log: [10/31/2008 8:38:12 PM] ==== COM5 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7F03:000D boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_52.BIN ver. sw2: MAUI.GEMINI.W08.12.52, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_52.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_52.BIN]_20081031-204001.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:18E59F00000000 Finalization Done Finished, time used: 128 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-03-2008, 21:36 | #5 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Yes pro solv but after format set insert sim. But customar sayes befour set dead set is parfact. What can i do pl. what is the prob? it's HW or SOFTWARE? |
11-04-2008, 16:16 | #7 (permalink) | |
Insane Poster Join Date: Mar 2008
Member: 715951 Status: Offline Thanks Meter: 0 | Quote:
Could you upload this flash file? I need it, please Thanks in advance | |
11-05-2008, 20:37 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, We will be glad if somebody can send this kind of full flash from good working phone to [email protected] so we will be able to upload good files for all users in support area. |
11-07-2008, 18:34 | #9 (permalink) | |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
flashfiles/ChineseMiracle/_MT6225/repair_eeprom/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_05__ffs_01.B0E.bin flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_05__ZTC-S600+_16m_En_Cn.B0M.bin | |
11-08-2008, 13:56 | #11 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | NO RESULT SIR, THIS FILE, WHY http://forum.gsmhosting.com/vbb/showthread.php?t=621014 THIS FILE CAN'T UPLOAD IN SUPPORT AREA? PL UPLOAD THIS FILE IN SUPPORT AREA. BECAUSE THIS FILE I READ FULLY GOOD CONDITION SET. |
11-08-2008, 20:40 | #12 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | this file (HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI _W08_12_52.BIN) and this file(HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GE MINI_ W08_12_05__ZTC-S600+_16m_En_Cn.B0M.bin) are not same. i try but no result. |
11-10-2008, 19:32 | #14 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | respected sir i sand this file in [email protected] name chinabluetooth pl upload this file in support area. -:THANKS:- |
11-10-2008, 21:47 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, There is no mails with flash files received yet. please, send file again to [email protected] |
i flashed lg b2060 ....after flash set dead..help. | Rin2 | Infinity-Box | 2 | 03-21-2010 06:01 |
china nokia 6300 after flash set gon white screen | sjni | Infinity-Box | 1 | 07-02-2009 12:38 |
C139 after unlock display white light | biniesh_08 | Motorola Hardware Repair | 0 | 03-02-2009 06:52 |
