07-15-2021, 10:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Europe
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | Alcatel 5030D Unlock issues - SUPPORT please check I'm trying to unlock this phone since y-day. First it was in system as queued then 'executing'. Program always say to 'try after 15min'. Please check, here logs: Card found : C7DF8299 , v0149 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 354828115717148 IMEI[2] : 354828115717155 IMEI[3] : 867400020316638 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 15, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! |
07-15-2021, 15:02 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That one has been with new revision/stock chip. Processed. Next ones will not have such issue. |
07-15-2021, 16:10 | #4 (permalink) |
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | Yes, thank you very much. Phone unlocked now! Operation : SP Unlock [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 354828115717148 IMEI[2] : 354828115717155 IMEI[3] : 867400020316638 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 15, price:5 Process... Finished Disconnected Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:48 |
07-17-2021, 16:18 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New models may need some time for calculation at server side. So if you will see a message Code: Process : Operation may took 10-15 minutes! |
