02-28-2009, 08:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Alcatel S211 Unlock Success module v1.30 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090228-124512.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 75 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to Mr.3. For This Useful Post: |
02-28-2009, 20:51 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
03-12-2009, 06:59 | #3 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: waiting nokia sl3 update
Member: 442421 Status: Offline Thanks Meter: 68 | Quote:
03-12-2009, 20:11 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
01-20-2010, 17:19 | #10 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1214145 Status: Offline Sonork: 504312 Thanks Meter: 0 | onlock ot s211 boot fail Buen dia, alguien sabe si ya se Puede desbloquear este modelo y la versión que en contra, e estado leyendo Acerca de este vídeo pero los que no hay venta nuevos soporte para el arranque, esto es lo que me con la venta infinito. Un cable de el proposito lo acabe de hacer hasta pense Qué estaba mal pero me da Continuidad Patillas con el que esta en el plano de este, si me pueden colaborar con esta informacion desde ya mil gracias. COM1 [VCP0] seleccionado Módulo v1.34 Dispositivo: Alcatel-S211 "La detección de chips Advanced" activo Acción: unlock Espere Comprobación de los datos, ... Boot ... El teléfono Debería APAGO! Pulse el botón Power Now! versión de la ROM: 0502 Conectando ... El arranque ... Finalizando ... De arranque no Error: Error en la operación Terminado, Utilizado El tiempo: 49 segundos / Eliminar batería Install now! |
02-01-2010, 12:27 | #13 (permalink) |
Freak Poster Join Date: May 2008 Location: ghana
Member: 782390 Status: Offline Sonork: oshiu Thanks Meter: 57 | Pls infinity pin finder cable to use should be L5A then you are done good luck COM8 selected module v1.38 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20100201-111245.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 1 min 39 sec Remove/Install battery now ! |
The Following User Says Thank You to OSHIU For This Useful Post: |
02-01-2010, 12:35 | #14 (permalink) |
alcatel bic phone s211 unlocked successfully | f164 | Infinity-Box | 8 | 08-17-2010 13:11 |
Alcatle S211 unlock successfully | adreesas | Infinity-Box | 2 | 08-20-2009 20:09 |
Alcatel s211 unlock done | yasermalik | Infinity-Box | 5 | 03-09-2009 07:26 |
Alcatel-s211 unlock done | saqibmalik | Infinity-Box | 6 | 02-07-2009 16:03 |
Alcatel S211 Unlock Problem, please help | naveed7791 | Infinity-Box | 1 | 01-06-2009 10:45 |
