12-17-2008, 19:28 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | alcatel bic phone s211 unlocked successfully COM3 [VCP0] selected module v1.30 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20081217-191411.80E.bin Read data done Check data ... Check data done Write ... ......... ......... ... flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 64 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to f164 For This Useful Post: |
12-17-2008, 20:14 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
07-20-2009, 16:25 | #3 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Spain
Member: 595735 Status: Offline Thanks Meter: 20 | bic i cant unlock it maybe new version COM1 [Serial0] selected module v1.34 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 46 sec Remove/Install battery now ! |
08-26-2009, 00:34 | #4 (permalink) |
Major Poster Join Date: Mar 2007
Member: 466637 Status: Offline Thanks Meter: 3 | COM1 [Serial0] selected module v1.35 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 46 sec Remove/Install battery now ! any help ...... please support |
08-26-2009, 08:31 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, it looks like that your phone has new CPU type that is not supported yet. |
04-20-2010, 15:57 | #6 (permalink) |
No Life Poster Join Date: Oct 2003 Location: South Spain
Member: 42553 Status: Offline Thanks Meter: 23 | Another unsupported Bic Phone COM8 [VCP0] selected module v1.38 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 46 sec Remove/Install battery now ! CPU is hidden under a metal shield, so I can't give you more info.. Last edited by NeTRaW; 04-20-2010 at 16:02. |
08-17-2010, 13:11 | #9 (permalink) |
Registered User Join Date: Oct 2004 Location: Tanzania Age: 47
Member: 86787 Status: Offline Sonork: www.sammy685344861 Thanks Meter: 31 | COM6 [VCP2] selected module v1.38 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 48 sec Remove/Install battery now ! |
Bic Phone S211 when will be supported | Iron Eagle | Infinity-Box | 5 | 06-17-2011 20:28 |
Alcatel S211 Unlock Success | Mr.3. | Infinity-Box | 15 | 02-01-2010 16:49 |
Alcatel BIC phone ERROR phone not conected [ANSWERED] | ProfesionalGSM | PolarBox 3 | 10 | 12-07-2009 06:33 |
Alcatel BIC Phone unlock error | ProfesionalGSM | Infinity-Box | 2 | 11-18-2009 17:56 |
Alcatle S211 unlock successfully | adreesas | Infinity-Box | 2 | 08-20-2009 20:09 |
