Old 11-19-2009, 02:52   #1 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
another pcb pinout n95 8gb dual sim, help
hello
Phone is alive and is sp-locked.
but find problem finding it rx/tx
cpu is mt6225
charge connector: mini usb 5pin
here's pic
[IMG]http://3.bp.********.com/_J-_GDh37_lc/SwPtVVzA4DI/AAAAAAAAAFU/k4GJrMxGVa4/s400/DSC01006.JPG[/IMG]
[IMG]http://1.bp.********.com/_J-_GDh37_lc/SwPtVnY9p-I/AAAAAAAAAFc/wPs2M0MGDb8/s1600/DSC01004.JPG[/IMG]
i had tried to use CM cable 5A, but failed detecting pins..
tried to use pin out from hf port, still no luck..
i also searched in this folder
c:\program files\infinity box\chinese miracle\pinout\
i couldn't find one matching this phone's pcb layout.
been searching forum, still didn't find one
then i tried this way:
http://forum.gsmhosting.com/vbb/show...pinout+n95+8gb
hello!
please take a look how easy is examinate your phone for correct pinout.
as you can see- battery is attached (phone powered On or not- does not metter). One multimeter probe is on GND (metall shield)
with another you touch one by one all points.
when you see 2,7-2,9 volts- this is Tx/Rx
On my example i am touching correct data pin (voltage 2,7 volts)
i found 3 places w/ output 2.74v
here's pic
[IMG]http://1.bp.********.com/_J-_GDh37_lc/SwPtVBcjiZI/AAAAAAAAAFM/DJ5Brsp2enc/s400/DSC01010edit.JPG[/IMG]
then i tried to combine it
1&2
1&3
2&3
as rx/tx, but pin finder still can't find it
help
Old 11-19-2009, 03:59   #2 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
i forgot to mention, i use ground also when searching, on gold line area left side pcb
Old 11-21-2009, 16:15   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try 1 and 2 again.
first time try 1 as tx, 2as rx
next time try 1 as rx, 2 as tx
both times your box ground pin 8 must be connected with grounded phone part
Help with N95 8GB dual card ricmes Chinese Models & Cloned Phones 1 12-08-2009 08:55
here is ew n95 8gb dubal sim pinouts imran_mobi Infinity-Box 4 03-08-2009 15:52
I need Pinout of n95 8gb single sim slider rascen76 Infinity-Box 1 09-04-2008 13:11
another pinout n95 slider single sim.... jcjibz2 Chinese Models & Cloned Phones 0 07-02-2008 14:47
n95 cineese dual sim pinout? .:R-mitik:. Infinity-Box 3 10-03-2007 07:21
Page generated in 0.13245 seconds with 9 queries
