Old 06-06-2009, 17:45   #1 (permalink)
Member: 983750
Thanks Meter: 26
blue 245x unlocking
sir
i want to sp unlock bleu 245x
i get 2 flash files from support area
Bleu-245x_CALCOMP-G250-VER-B01.03-20070808_(245x_32+8)_ver2.70M
COM2 [VCP0] selected
Checking data, wait...
Connect...
Press Power button now !
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
flash: BF7353FFFF0052:00008500000000
flash: SST SST34HF3244/3284 U 4Mb
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: C:\Program Files\InfinityBox\PModule02\eeprom_calibration__20 090606-220251.70E.bin
Check space Ok
Write...
Area: Firmware
Write: Firmware
error: no any expected answer
error: flash write error: 02000000:00002000
Write failed
Finished, remove/install battery now !
Time used: 55 sec
and i try with another file
Bleu-245x_CALCOMP-G250-VER-B01.03-20070808_(245x_32+8).70M
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: C:\Program Files\InfinityBox\PModule02\eeprom_calibration__20 090606-220356.70E.bin
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write Ok
Close...
Close Ok
Restart...
Restart Ok
Time used: 222 sec
but my set not power on what to do
Old 06-09-2009, 07:08   #2 (permalink)
Member: 983750
Thanks Meter: 26
blue 245x unlocking
sir
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write failed
Time used: 55 sec
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write Ok
Close...
Close Ok
Restart...
Restart Ok
Time used: 222 sec
Old 06-16-2009, 07:26   #3 (permalink)
Member: 983750
Thanks Meter: 26
blue 245x unlocking
sir
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write failed
Time used: 55 sec
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write Ok
Close...
Close Ok
Restart...
Restart Ok
Time used: 222 sec
Old 06-24-2009, 07:06   #4 (permalink)
Member: 983750
Thanks Meter: 26
blue 245x unlocking
sir
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write failed
Time used: 55 sec
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
Check space Ok
Write...
Area: Firmware
Write: Firmware
Write Ok
Close...
Close Ok
Restart...
Restart Ok
Time used: 222 sec
Old 06-28-2009, 10:49   #5 (permalink)
Member: 983750
Thanks Meter: 26
plz reply if any body is here
Old 06-28-2009, 11:58   #6 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
man this is not the way to get a reply ...
blue 245x unlocking pankaj_gsm Infinity-Box 0 07-19-2009 12:50
need blue 245x unlocking inderje Infinity-Box 0 04-29-2009 11:10
Need CPF II Blue 245x Unlock File 5700 CPF-BOX Ⅱ 2 04-10-2009 14:00
blue 245x 145x unlock ? doller Infinity-Box 4 04-24-2008 21:22
Page generated in 0.19121 seconds with 9 queries
