01-16-2007, 15:55 | #1 (permalink) |
Freak Poster Join Date: Aug 2003 Location: pakistan Age: 47
Member: 36550 Status: Offline Sonork: 100.1605076 Thanks Meter: 7 | c168 dead i have c168 which was on phone lock i read the cde that was 7241 but when i apply this on mobile ti says incorrect password now i flash it but it gives error on flash and now phone is dead plz help me this is flash log COM4 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try to recover erase error#43 many thanx |
01-16-2007, 17:59 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | 1: to reset phone code just press format ffs, no need to flash. 2: try to flash ur phone again with same firmware flashing will start from same point. no need to worry. got this problem many times. if phone does not boot check battery, use fully charged one |
01-27-2007, 19:02 | #5 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 141927 Status: Offline Thanks Meter: 27 | c168 flash error Flashing error my moto c168 (that phone c168) ERROR COM3 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1490)000 HW ver: PCP-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFBFFFB flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFBFFFB flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Err: error verify try#1 to recover write error at 00000000 Err: flash end try#2 to recover write error at 00000000 Err: answer#00 try#3 to recover write error at 00000000 Err: answer#00 try#4 to recover write error at 00000000 Err: answer#00 try#5 to recover write error at 00000000 Err: answer#00 try#6 to recover write error at 00000000 Err: answer#00 try#1 to recover write error at 00002000 Err: answer#00 try#2 to recover write error at 00002000 Err: answer#00 try#3 to recover write error at 00002000 Err: answer#00 try#4 to recover write error at 00002000 Err: answer#00 try#5 to recover write error at 00002000 Err: answer#00 try#6 to recover write error at 00002000 Err: answer#00 try#1 to recover write error at 00004000 Writing Fail Finished, time used: 241 sec Remove/Install battery now ! please help inifinity team............. Last edited by pugazhendhi; 01-27-2007 at 19:05. Reason: fault |
01-27-2007, 19:42 | #7 (permalink) |
Member: 141927 Status: Offline Thanks Meter: 27 | battery ok,c168 flash error.JPGplease see error |
02-08-2007, 03:54 | #13 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | Quote:
02-08-2007, 07:11 | #14 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | try to unlock ur phone. 1:do prepare procedure with repair unauthorised option checked 2:sp unlock 3:reset settings it worked for me hope it 'll work 4 u 2 |
help c168 dead!!!!!!!!!!!!! | GSM PAVIA | Infinity-Box | 13 | 06-13-2008 17:19 |
c168 dead........... | ..:MumbaiGsm:.. | Infinity-Box | 3 | 05-07-2007 10:05 |
motorola C168 dead help | therocky8 | Infinity-Box | 3 | 11-29-2006 10:35 |
C168 dead in change language | ARC | Infinity-Box | 9 | 11-23-2006 18:36 |
c168 dead for unlock | gabriel148 | Infinity-Box | 11 | 11-11-2006 18:29 |
