09-10-2015, 16:08 | #32 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | ITEL it1501 REPAIR SECURITY DONE. Thanks for great update Quote:
The Following User Says Thank You to kawalya For This Useful Post: |
09-11-2015, 00:32 | #34 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 356 | Quote:
I will upload as soon as I arrive home. and will PM you details | |
09-12-2015, 10:07 | #37 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: ==== Wait for phone... Phone found! [ 114 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 1254789 Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
09-12-2015, 16:14 | #38 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2039241 Status: Offline Thanks Meter: 5 | Code: Wait for phone... Phone found! [ 48 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00C1C73493CFD5 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_gionee77_cu_ics2.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img Brand : Fly ProdName : Fly ProdModel : IQ441 Device : Fly AndroidVer: 4.2.2 MTKxCPU : MT6577 MTKxPRJ : ALPS.JB2.EXT.MP.V1.9 [ScatCFG] : MT6577 / V1.0.0 / gionee77_cu_ics2 / EMMC FW Size : 549 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6577__Fly__IQ441__Fly__4.2.2__ALPS.JB2.EXT.MP.V1.9\ All done! Done! Elapsed: 00:04:29 Reconnect Power/Cable! |
09-12-2015, 16:35 | #39 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile e9 read code done Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 7BC61F1F9975FC7CA9B949399C0ACF60 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 7800 Privacy Lock :U Done! BR GSM BOSS |
09-12-2015, 16:54 | #40 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That thread is about SPD, not MTK. Sucess logs can be posted here : http://forum.gsmhosting.com/vbb/f296...iatek-1862422/ |
09-13-2015, 22:22 | #42 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,962 | New version released - http://forum.gsmhosting.com/vbb/f296...c8830-1990983/ |
09-14-2015, 10:32 | #43 (permalink) |
Member: 2039241 Status: Offline Thanks Meter: 5 | Alcatel 4007d Reset Screen Lock failed! Code: Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0088 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
