03-31-2014, 12:33 | #110 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 42
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | China RAD cpu phone after format restart not done please fix this. readed file is here. https://mega.co.nz/#!VxoTHJYL!vWOzIZ...2SKA3PMX3WQRdg here is logs. Card found: S/N 9176:0118 Chinese Miracle II [RDA module] v 0.05 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Error on boot , check cable, try again Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Error on boot , Init Failed (Power Button release to early) Hold Power Button until 'Release button' message appear in log, try again Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Error on boot , Init Failed (Power Button release to early) Hold Power Button until 'Release button' message appear in log, try again Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Error on boot , Init Failed (Power Button release to early) Hold Power Button until 'Release button' message appear in log, try again Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Error on boot , Init Failed (Power Button release to early) Hold Power Button until 'Release button' message appear in log, try again Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:05 Done Reconnect Power/Cable! Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:42 Done Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:02 Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : MODERN_V1_03 Project Info : 8851a_817_L6 Compile Date : 20130425Thu1152 [BIN] Saved as : MODERN_V1_03_8851a_817_L6_CT8851A_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\MODERN_V1_03_8851a _817_L6_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\MODERN_V1_03_8851a _817_L6_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:18:27 Reconnect Power/Cable! |
03-31-2014, 16:12 | #111 (permalink) | ||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Because boot not done, as I can see. Please, try next time hold and press power button little longer, until "Release button" message will appear in log. | ||
03-31-2014, 17:06 | #113 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Checked FW - it looks normally, as and rest data. Need find same phone or flash and try flash it with factory sets. Should help , if still no luck - seems as need resolder/rehot RDA CPU/SOC. |
The Following User Says Thank You to Dzirt For This Useful Post: |
03-31-2014, 17:22 | #114 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | Quote:
i know im post in wrong place ,but plz add mtk and spd new models .i will dailly seccesfull post ,every body say infinty is dead project ,just finish this name from infinty sory for wrong place post | |
03-31-2014, 17:44 | #115 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Quote:
i have readed flash file also set is on condition and in my hand till now. | |
03-31-2014, 19:09 | #116 (permalink) | |||
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | MJphone mini M1000 Read Info Quote:
04-01-2014, 12:20 | #117 (permalink) |
Freak Poster Join Date: Apr 2009 Location: "CELL SOLUTION"...udupi Age: 38
Member: 1019517 Status: Offline Sonork: 100.1614559 Thanks Meter: 102 | Gtel x2.02 Read info free image hosting Read user code free image hosting Read full Flash free image hosting Format free image hosting |
04-01-2014, 14:03 | #118 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2108593 Status: Offline Thanks Meter: 839 | format error Start at : [4/1/2014 / 5:59:45 PM] Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 00000004 , 00000018 CSD DR : 00160016 , 00180018 , 001A001A CSD MB : 001C001C General Error , Registers Init not passed! Elapsed: 00:00:07 Reconnect Power/Cable! Finish at : [4/1/2014 / 5:59:53 PM] |
04-01-2014, 14:19 | #119 (permalink) | |
http://forum.gsmhosting.com/vbb/f296...assed-1797316/ Please, next time just make flash read and send dump , it will help us make all what possible for improve that in next versions. | |
