Old 03-31-2014, 07:54   #106 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
JASO J10 repair ime done
The Following User Says Thank You to sultan_ For This Useful Post:
Old 03-31-2014, 08:36   #107 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
G VILL model 301 hang on logo done with format
Old 03-31-2014, 08:56   #108 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
Samsung model a2688 RDA 8853b read code error
Old 03-31-2014, 09:27   #109 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
Gfive w39 RDA8851 read code error
Please check and solve this bug
Old 03-31-2014, 12:33   #110 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
China RAD cpu phone after format restart not done please fix this.
readed file is here.
https://mega.co.nz/#!VxoTHJYL!vWOzIZ...2SKA3PMX3WQRdg
here is logs.
Card found: S/N 9176:0118
Chinese Miracle II [RDA module] v 0.05
Operation : Format File System
Settings : SmartFormat is On
Com Port Opened
Press and hold POWER button!
Waiting phone
Error on boot , check cable, try again
Reconnect Power/Cable!
Operation : Check Device / Info
======= Settings
Settings : Read AllInfo is Off
Settings : Full Boot disabled by default
Com Port Opened
Waiting phone
Error on boot , Init Failed (Power Button release to early)
Hold Power Button until 'Release button' message appear in log, try again
======= Settings
Com Port Opened
Waiting phone
======= Settings
Com Port Opened
Waiting phone
======= Settings
Com Port Opened
Waiting phone
======= Settings
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4006
CPU_CN : RDA Micro CT , RDA8851
==== FLASH
FL_VEN : 40C8 , rev : 1600
FL_CNM : GigaDevice , GD25Q32
FL_CAP : 00400000
==== Booting
Sending RamRun Loader...
Use : 8809_00400000.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Loader run
Boot Ok
Release Power button!
Boot Done!
Elapsed: 00:00:05
Done
Operation : Read User Code
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read done, sorting EXTData
Following items found :
Item : NVRAM
Required data found, extracting code
UserCode : 1234
Elapsed: 00:00:42
Done
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
NVMFAT Area : 0x003A0000 , Len : 0x0005C000
Range as Factory Defined
Format User Area ...
CSD WR : 81C05C48 , 81C05C5C
CSD DR : A2000000 , A2008000 , A2010000
CSD MB : 00008000
Format Done
Elapsed: 00:01:02
Operation : Read FullFlash
======= Settings
Settings : SafeMode is Off [Fast]
Settings : Make IFF (MCU) file
Settings : Make Calibration file
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
Read Flash now ...
Read Ok, 4194304 bytes read
Verify file...
Target BbCpu : CT8851A
Target Flash : flsh_spi32m
Project Name : MODERN_V1_03
Project Info : 8851a_817_L6
Compile Date : 20130425Thu1152
[BIN] Saved as : MODERN_V1_03_8851a_817_L6_CT8851A_flsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\MODERN_V1_03_8851a _817_L6_CT8851A_flsh_spi32m.iff
[CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\MODERN_V1_03_8851a _817_L6_CT8851A_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:18:27
Old 03-31-2014, 16:12   #111 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello. Phone is alive? It not formated? If it alive and not factory reseted - it must chow code. Please, if it happen again with alive phone, which ask code - read flash and we will solve it.
What phone condition after format? It nopt power on? Blink? Or something else? Need more info to determine problem.
Because boot not done, as I can see.
Please, try next time hold and press power button little longer, until "Release button" message will appear in log.
Old 03-31-2014, 16:48   #112 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
@Dzirt
Phone problem is restart after pressing any keys.
After format the phone problem is same.
BR.
Siddeque
Old 03-31-2014, 17:06   #113 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
@Dzirt
BR.
Siddeque
Checked FW - it looks normally, as and rest data. Need find same phone or flash and try flash it with factory sets. Should help , if still no luck - seems as need resolder/rehot RDA CPU/SOC.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 03-31-2014, 17:22   #114 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
bro Dziert
i know im post in wrong place ,but plz add mtk and spd new models .i will dailly seccesfull post ,every body say infinty is dead project ,just finish this name from infinty
sory for wrong place post
Old 03-31-2014, 17:44   #115 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
i checked with other tool and done
i have readed flash file also set is on condition and in my hand till now.
Old 03-31-2014, 19:09   #116 (permalink)
Member: 621121
Thanks Meter: 366
MJphone mini M1000
Read Info
Card found: S/N xxxx
Start at : [3/31/2014 / 11:55:57 PM]
======= Settings
Settings : Read AllInfo is On
Waiting phone ...
Connect battery, press and hold '0' button
Connect USB cable and keep hold button, until phone will be detected
Init : 55555555
Settings registers ...
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4005
CPU_CN : RDA Mirco CT , RDA8851
==== FLASH
FL_CAP : 00400000
Initial : 81C0024C
Boot Done!
Checking step #1, wait ...
Checking step #2, wait ...
Elapsed: 00:00:19
Done
Read User code
Waiting phone ...
Init : 55555555
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending RamRun Loader ...
Use : 8809_00400000_usb.fp
Sending HdrConf ...
Sending LdrData ...
Flush : 0400F000
Loader run
Boot Done!
Item : VDS0
Item : NVRAM
UserCode : 1234
Elapsed: 00:00:03
Done
Read Full flash
======= Settings
Waiting phone ...
Init : 55555555
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending HdrConf ...
Sending LdrData ...
Flush : 0400F000
Loader run
Boot Done!
Read Flash now ...
Verify file...
Project Name : C205_KC_3127C_RDA8851A_ST3216_PCB20_QQVGA_MUL7_EBI _MUPHONE_V01
Project Info : C205_RDA8851A_3216_QQVGA_KC
Compile Date : 20130110Thu1156
[BIN] Saved as : C205_KC_3127C_RDA8851A_ST3216_PCB20_QQVGA_MUL7_EBI _MUPHONE_V01_C205_RDA8851A_3216_QQVGA_KC_CT8851A_f lsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C205_KC_3127C_RDA8 851A_ST3216_PCB20_QQVGA_MUL7_EBI_MUPHONE_V01_C205_ RDA8851A_3216_QQVGA_KC_CT8851A_flsh_spi32m.iff
[CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C205_KC_3127C_RDA8 851A_ST3216_PCB20_QQVGA_MUL7_EBI_MUPHONE_V01_C205_ RDA8851A_3216_QQVGA_KC_CT8851A_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:00:39
Old 04-01-2014, 12:20   #117 (permalink)
faizal313's Avatar
Member: 1019517
Sonork: 100.1614559
Thanks Meter: 102
Gtel x2.02
Read info
free image hosting
Read user code
free image hosting
Read full Flash
free image hosting
Format
free image hosting
Old 04-01-2014, 14:03   #118 (permalink)
Member: 2108593
Thanks Meter: 839
format error
Start at : [4/1/2014 / 5:59:45 PM]
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_VEN : 60C8 , rev : 1600
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD WR : 00000004 , 00000018
CSD DR : 00160016 , 00180018 , 001A001A
CSD MB : 001C001C
General Error , Registers Init not passed!
Elapsed: 00:00:07
Finish at : [4/1/2014 / 5:59:53 PM]
Old 04-01-2014, 14:19   #119 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Com Port Opened
Waiting phone
Init Ok
1st boot Ok
==== CPU
==== FLASH
FL_CAP : 00400000
==== Booting
Sending HdrConf ...
Sending LdrData ...
Loader run
Boot Ok
Boot Done!
CSD MB : 001C001C
Elapsed: 00:00:07
Answer already given :
http://forum.gsmhosting.com/vbb/f296...assed-1797316/
Please, next time just make flash read and send dump , it will help us make all what possible for improve that in next versions.
Old 04-01-2014, 17:10   #120 (permalink)
sultan_'s Avatar
Member: 770299
Sonork: 100.1603105
Thanks Meter: 1,029
MTK n200 hang when display light off done with write flash
Page generated in 0.25607 seconds with 9 queries
