01-28-2010, 22:47 | #1 (permalink) |
Junior Member Join Date: Nov 2005 Location: San antonio, chile
Member: 200900 Status: Offline Thanks Meter: 10 | correct for flashing with infinity signmatel zn4 I hope that I can not help what is the correct process for flashing with infinity I gave him the phone and read it with a sigmatel ZN4 firmware version: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN what I do is this lower the flash and eeprom the charge with chinese miracle in the Flash tab v3.07 firmware and eeprom cargol while I write him flashing ends give him a standart lock and does not start after that. I'm sticking by flashing the software after a while lei read the full flash and eeprom to reload and switch the phone off again but maybe it flsh problem or the process will not do reading the attached information from the fono detecting chip # 00 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip # 01 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip # 02 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 000802000 00FEx010000 0008x002000] 16Mb detecting chip # 03 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip / regions detected: 04/01 Start Done ====> Select gear ... 921600 Select Done speed ====> Start bootcode ... Start bootcode Done ====> Check firmware integrity ... device parameters detection in progress ... detecting chip # 00 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip # 01 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb It's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip / regions detected: 01/01 Total size of the region flashed: 01000000 bootloader usb detect ... .. bootloader usb detect (phase # 2) ... .. usb bootloader (chip) is absent rom searching info ... rom info search finished rom info structure: 2nd [standard] generation TCL-ID is absent info rom detection finished rom info see: 04 sw version: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 offset code: 00000000 ffs offset / size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs / eeprom area in 1 chip (s) ... standard ffs / eeprom offset detected: 00E00000 standard ffs / eeprom offset confirmed: 00E00000 detecting ffs / eeprom size ... ffs / eeprom size: 00200000 ffs / eeprom chip: 00 ffs / eeprom area: 00000000:00 E00000-00ffffff detecting ffs / eeprom structure pass 1 ... ........................ detect standard ffs / eeprom location pass # 1 ... .................................................. ..... detect standard ffs / eeprom offset pass # 1 ... ffs / eeprom offset record detected detect standard ffs / eeprom data ... ffs / eeprom detected record size ffs / layout detection complete eeprom ffs / eeprom detected ok: element # 1 sec info (detailed) detection ... searching sec info # 1 ... . search info # 1 finished sec detecting firmware version ... firmware version: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN detecting firmware build ... .................................................. ..... firmware build: + 1CGEMINIMAUI.GEMINI.W08.12KCM25_GEMINI_HW2009-06-0115-52 detecting product-id ... .................................................. .............. Clever detecting languages ... ................................................. language parameters detected detected languages: In Ru Fr Th Vn Is It Id Farsi Pt Tr Ar sec info (detailed) detection ... searching sec info # 1 ... . search info # 1 finished sec Finished, time used: 2 min 9 sec Remove / Replace the battery now! [/COLOR] I hope I pudan help. Last edited by InfinityHelp; 01-29-2010 at 11:44. |
spice s600 success fully repaired by flashing with infinity & flash file at sopport s | sabby_singh | Infinity-Box | 2 | 11-02-2011 16:22 |
.:::::kg275 blinks after flash with infinity help infinity support ::::::. | SAMEER TAHIR | Infinity-Box | 1 | 09-16-2008 20:58 |
İs posible flashing with infinity for sony ericcson w800i? | islam01 | Infinity-Box | 1 | 07-04-2008 12:13 |
is this cable mt n95 connection correct for flashing | dvdaio | MT-BOX | 14 | 09-05-2007 10:45 |
is this cable mt n95 connection correct for flashing | dvdaio | MT-BOX | 0 | 07-15-2007 21:09 |
