02-20-2006, 08:53 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Is it your first installation attempt or dongle was working before ? Pls, check this. maybe this can help. http://forum.gsmhosting.com/vbb/showthread.php?t=271136 |
02-20-2006, 11:18 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | also try this pls: http://forum.gsmhosting.com/vbb/show...ghlight=repair |
02-21-2006, 01:30 | #4 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Djazair
Member: 111121 Status: Offline Sonork: 100.99340 : CrKdz13 Thanks Meter: 487 | Quote:
XP sp2 celeron 1.7 GHZ chipset VIA ps: the smart card repare tool don't do anything & before this problem i'had installed the new driver from the UST-pro2 "2.6" and your driver is 2.4. no solution ????? excuse my poor english | |
02-21-2006, 08:49 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How about ust ? is it working good on this PC ? Could you send me drivers from ust package to test ? Could you try to uninstall drivers ver 2.6 and install 2.4 back ? |
02-21-2006, 10:53 | #6 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia Age: 42
Member: 17711 Status: Offline Thanks Meter: 1,858 | shaytan: On your computer Smart Card Manager Service is not starting or has not been started. That repair tool requires you to REBOOT after each step. Have you rebooted after performing first and second steps in software? So, the exact procedure is: - Make Step 1 - Reboot - Make Step 2 - Reboot - Try to start Infinity You can check service state from Control Panel: Control Panel -> Administration -> Services -> Smart Cards (scardsvr). This service's start up type must be set to Automatically and it should be running. If it is not - start it up. You can also start it up by executing command net start scardsvr |
01-31-2007, 21:03 | #7 (permalink) |
Banned Join Date: Jun 2003 Age: 46
Member: 31047 Status: Offline Thanks Meter: 0 | I have this problem too with my box INFINITY. It can't connect. When I plug it after installing drivers, it says your device is now conncted and now ready for using. But when I go to EMERALDACLIENT for the registration it refuses.I do everething but no sucess, all your instructions but no way. Pls advise what is happenning because it's very strange for me. Thx |
01-31-2007, 21:37 | #8 (permalink) | |
Yes, it's very strange but there is one very easy way: http://forum.gsmhosting.com/vbb/show...63&postcount=2 please, read above mentioned link carefully. If you did not find answer for your problem please, describe your problem exactly ! Attach log file (text from log window) etc. | |
02-01-2007, 12:57 | #9 (permalink) |
Member: 31047 Status: Offline Thanks Meter: 0 | INFINTY BOX refuses to connect I see all the three devices following your instructions: 1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator 2. Smart card readers -> e-gate USB Smart card reader 3. e-gate USB Smart Cards -> e-gate USB Smart Card and when I run EmeraldaClient to register It says "Dongle can't be found: Card with specified AID not found! Smart Card API error# 0 Opération réussie Then I go to check Emeralda.log, It's empty. So the box can't connect. Pls help coz I need it. Thx. |
04-09-2009, 09:52 | #11 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 596251 Status: Offline Thanks Meter: 33 | infinity-box ----------Process started: 2:47:57 PM---------- Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 482, Firmware: 0112.02 Authenticating on server... Authentication stage error: Server reported error:[0006] Your account is suspended: read previous error messages carefully and contact to [email protected] help. |
04-09-2009, 13:02 | #12 (permalink) | |
05-12-2009, 10:28 | #13 (permalink) | |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | same problem with me pls help Quote:
infinity team i dnt use my infinity box for 1 year now i start again but whn i install infinity set up it says api error #ooooooo | |
LG3G 1.20 sysem driver error | kimd81 | VygisToolbox | 1 | 09-18-2008 09:21 |
K500 Camera driver error!!! | tittu | SonyEricsson (USB-Smart) | 1 | 03-15-2006 22:53 |
K500 Camera driver error!!! | tittu | Sony Ericsson Hardware Repair | 0 | 03-09-2006 17:28 |
Camera driver error! | kojote | Sony Ericsson Hardware Repair | 0 | 09-11-2004 11:45 |
Hellomoto - USB driver ERROR...!!!!!! | bladecomms | Motorola P2k | 14 | 04-27-2004 17:28 |
