Old 04-16-2018, 13:55   #1 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile Finally MTK Module is Ready !!! Download InfinityBox_install_CM2MT2_v2.00
This release DO NOT require Smart-Card update! Smart-Card version required is 01.36
MTK 6570 CPU support:
with NAND memory
with eMMC memory
Read Info - Complete device info, Security info
Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ]
Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ]
Read NVRAM
Write NVRAM
Repair Security
Formay FS - FRP, Settings, Privacy ( and mixed/special mode )
MemoryTool
MTK 6750 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6755 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6757 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6763 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6797 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
Under Test --------------------------------------------------------
MTK 6758 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6739 CPU support:
with NAND memory
with eMMC memory
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
Main
- New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ]
- New core. All code made from scratch.
- New boot chain selection mode - automatic ( via defined user combination ) or manual.
- New connection
- Complete error handling and explanation
- Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices
- Easy end user customization for adding support for new device and e.t.c.
Flasher
- Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ]
FW Reader
- Completely new core, which allow handle all existing types and flash devices.
Service
- Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct.
- Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection )
- During NVRAM read/write SW also verify it condition and data
MEMORY TOOL activated!
Easy, fast and ultimate solution now come in MTK too!
- Support eMMC and NAND flash IC`secure
- Allow READ, WRITE, ERASE partitions
- Show partitions states and info only for eMMC devices
- Allow RE-init PMT ( from scatter )
Other
Lot of other changes from v1 line, which not mandatory to mention
Known issues/warnings/info:
1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-write data, which you want, ignore "EMPTY" states.
4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar
In some cases WIPE partition may not work!
5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing
6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
7. Device with NV_TYPE2 security may not work yet for repair sec!
http://dl1.infinity-box.com/download...M2MT2_v2.00.7z
The Following 69 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 04-16-2018, 14:01   #2 (permalink)
Member: 2829345
Thanks Meter: 6
thank you for the update.
Old 04-16-2018, 14:04   #3 (permalink)
Member: 1788877
Thanks Meter: 482
Woohooo
Thx
Back to my baby dongle cm2
Old 04-16-2018, 14:09   #4 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Finally Infinity team again comes on The Top Love You infinity Team .
The Following 3 Users Say Thank You to Luckey1 For This Useful Post:
Old 04-16-2018, 14:13   #5 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 307
boom no lolocano copy it
Old 04-16-2018, 14:14   #6 (permalink)
Member: 2509080
Thanks Meter: 24
Thanks 4 update. Waiting it 4 a long long time
Old 04-16-2018, 14:14   #7 (permalink)
Member: 2669781
Thanks Meter: 1,839
Oh baby Dongle is back.. I'm happier than a groom hahaha
Old 04-16-2018, 14:16   #8 (permalink)
Member: 2588227
Thanks Meter: 14
bomb update thx team .
Old 04-16-2018, 14:17   #9 (permalink)
Member: 2671601
Thumbs up thanks
thank for update mtk update very long time
Old 04-16-2018, 14:17   #10 (permalink)
cr7.azick's Avatar
Member: 2365156
Thanks Meter: 112
Index of pub/software/ Already uploaded on Support! Download and ENJOY! BINGOOO INFINITY TEAM!
Old 04-16-2018, 14:18   #11 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
GreaT Team Blast UPDATE , Thanks Bro : Kashan Aslam - Infinity Team & JayDi
Old 04-16-2018, 14:19   #12 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 948
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r1
Operation : Identify [ v2.00 r1 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM34)
MODE : BOOTROM
PORT : 34
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6572 , SBID : 0x8B00 , HWVR : 0xCA01 , SWVR : 0x0000
TYPE : LEGACY MTK
Info : Device is not supported yet!
Reconnect Power/Cable!
MODE : BOOTROM
PORT : 34
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : BOOTROM
PORT : 34
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
Old 04-16-2018, 14:19   #13 (permalink)
Member: 2332823
Sonork: 100.1662161:modern-mobile
Thanks Meter: 463
Infinety team where is emmc test in new cm2mt2 ?
Old 04-16-2018, 14:20   #14 (permalink)
Member: 2404180
Sonork: shakeellakhho
Thanks Meter: 2
Thanks for free update no need extra cost for it
Old 04-16-2018, 14:21   #15 (permalink)
devika's Avatar
Member: 78028
Thanks Meter: 90
PTFN : MediaTek PreLoader USB VCOM (Android) (COM3)
MODE : PRELOADER PORT
PORT : 3
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6795 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
solution
The Following 4 Users Say Thank You to devika For This Useful Post:
Page generated in 0.22603 seconds with 9 queries
