04-19-2009, 10:12 | #1 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 914747 Status: Offline Thanks Meter: 22 | fly sl500i flash error plz any body teseted saloution thanks in advance COM1 [VCP0] selected module v2.67 Device: Fly-SL500i Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:0941:C154 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881100010001:29EA0000000000 flash: 89881100010001:29EA0000000000 number of flash chip/regions detected: 00/01 flash chip is unknown or damaged, operation aborted. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 23 sec Remove/Install battery now ! br AY29!4LYF |
04-19-2009, 17:01 | #2 (permalink) | |
1. download and install latest MModule v2.70 2. try to flash phone again 3. post log here But I think that if it will be no luck with latest software too - you need to open phone and check it's hardware. | |
04-19-2009, 18:48 | #3 (permalink) |
Member: 914747 Status: Offline Thanks Meter: 22 | i open fone was damedge a bit of water but da flash ic is safe from every where glue every where on the side of ic i'll try latest software nd i'll post result thanks \ nd sorry i got 1 j110i sonyericsson every time call error any good nd tested saloution thanks again |
04-20-2009, 11:31 | #6 (permalink) |
Member: 914747 Status: Offline Thanks Meter: 22 | fly on latest setup COM1 [VCP0] selected module v2.70 Device: Fly-SL500i Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:0941:C154 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881100010001:29EA0000000000 flash: 89881100010001:29EA0000000000 number of flash chip/regions detected: 00/01 flash chip is unknown or damaged, operation aborted. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 26 sec Remove/Install battery now ! thanks |
04-20-2009, 17:45 | #7 (permalink) | |
Regarding Fly: I think you need to double check phone hardware due to it's very strange that software can not detect flash chip type well. In most cases it's hardware problem. | |
Fly Slt100 Flashing Error | Nasmi | Infinity-Box | 9 | 06-12-2013 13:04 |
Fly SL500i Dead after flash | mwmobile2 | Infinity-Box | 10 | 08-20-2010 15:16 |
fly B700 flash error!!!!!!!!!!!! | msantar | Infinity-Box | 9 | 10-08-2009 10:43 |
fly sl500i after flash dead | denny86 | Infinity-Box | 6 | 08-05-2009 19:14 |
unlocking code for fly sl500i and fly sl600! | Rebecca12345 | Phone Unlocking Codes & Maps | 1 | 06-14-2008 10:27 |
