Old 01-05-2021, 07:40   #1 (permalink)
Member: 477842
Thanks Meter: 80
FRP in Q Snapdragon 665, MTK MT6771T posibble ?
Hi brothers
I need to reset frp in mobile CHIP :
CHIP : Qualcomm Snapdragon 665
GPU: Adreno 610
and
CHIP : MediaTek Helio P70 MT6771T
GPU: ARM Mali-G72
any module in infinity box can do that ?
Old 01-05-2021, 14:55   #2 (permalink)
Member: 477842
Thanks Meter: 80
any one do this with cm2 QLM from infinity box module ?
Old 01-05-2021, 23:02   #3 (permalink)
Member: 1677653
Thanks Meter: 2,769
Read info with Infinity-Box CM2 module and post log ]
Old 01-11-2021, 14:05   #4 (permalink)
Member: 477842
Thanks Meter: 80
Read in Recovery mode ?
Old 01-11-2021, 17:03   #5 (permalink)
Member: 477842
Thanks Meter: 80
Use, Flash mode (VOL+ and VOL- ) connect to PC and Use MTK Module : Oppo F5 andhere is log :
Operation : Identify [ v2.16 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM18)
MODE : BOOTROM
PORT : 18
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Sylvia
TYPE : MODERN RAPHAEL
BROM : MEID : 3A0A1E81F0FC393F1B95A56B4955CF72
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : Oppo : F5 | Manual : Disabled
BROM : SOCID : 35A9D79C82DCDCB867747D1658DB01026894D509B114424C57 3151A4AFDC95BF
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 1001 0000 [0200] F3: 1001 0000 F7: 0000 0000 V0: 0000 0000 [0001]
BROM : SLA
BROM : Selected Auth/Cert not accepted by device!
>>> Check previous message for more info!
BUT I have problem with identify another phone : Qualcomm Snapdragon 665
Old 01-11-2021, 17:03   #6 (permalink)
Member: 477842
Thanks Meter: 80
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : BOOTROM
BROM : SLA
Old 01-11-2021, 20:12   #7 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : BOOTROM
BROM : SLA
Hi, in the mtk module you need custom da file, auth.file, preloader.bin and depending on the security of the mobile.
With the qualcomm idem theme, you need a custom loader and it will surely give you an error, because you need authorization to the server.
It would also be very helpful if you indicate which phones they are, the more information the users provide, the better for others, if you do not comply with the basic rules of the forum and the section in question they will not answer.
Old 01-12-2021, 11:13   #8 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
665 not.
MT6771 - what model exactly you have?
Old 01-12-2021, 11:38   #9 (permalink)
Member: 477842
Thanks Meter: 80
Originally Posted by JayDi View Post
665 not.
It`s OPPO A91 Global
Old 01-12-2021, 11:42   #10 (permalink)
JayDi's Avatar
Member: 462970
Oppo in almost every device line uses own security keypairs.
It will not work with internal loaders.
Seems as look for authorised service or isp/emmc direct.
Old 01-12-2021, 11:48   #11 (permalink)
Member: 477842
Thanks Meter: 80
This is two OPPO models
1.
OPPO A52 (PDAM10, CPH2069)
Qualcomm Snapdragon 665 GPU: Adreno 610
2.
OPPO A91 Global (CPH2001, CPH2021)
MediaTek Helio P70 MT6771T GPU: ARM Mali-G72
So, what I need to hard reset/reset frp in this phones via Infinity Box ?
Old 01-12-2021, 12:46   #12 (permalink)
Member: 477842
Thanks Meter: 80
You write about boxes with EMMC/ISP module (JTAG) ?
Old 01-12-2021, 12:59   #13 (permalink)
JayDi's Avatar
Member: 462970
Yes, about them. USB cable here not enough yet.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 01-13-2021, 08:01   #14 (permalink)
Member: 1835756
Thanks Meter: 718
any plan to launch ur own ufs emmc tool?
Old 01-13-2021, 21:51   #15 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
Oppo use *.cert file with *.auth
.01/12/21 14:01:16.076 BROM_DLL[13792][8732]: AUTH_GetInfo(): AUTH_HANDLE->rwlock: READ_UNLOCK. (rwlock.cpp:423)
01/12/21 14:01:16.076 BROM_DLL[13792][8732]: SCERT_GetInfo(): SCERT_HANDLE->rwlock: READ_LOCK ... (rwlock.cpp:407)
01/12/21 14:01:16.076 BROM_DLL[13792][8732]: ERROR: SCERT_GetInfo(): <ERR_CHECKPOINT>[300][error][5007]</ERR_CHECKPOINT> [S_FTHND_FILE_IS_NOT_LOADED_YET] (flashtool_handle.cpp:2441)
Page generated in 0.40904 seconds with 8 queries
