Old 08-16-2010, 08:21   #1 (permalink)
Member: 779599
Thanks Meter: 59
infinity pin finder need help
hello infinity team pls help me in solving my problem with my pinfinder. my infinity box cant detect pinder pls help me .
action taken: remove set up and reinstall again no luck. install latest pinfinder set up . but still no luck i doubt why it happen i use my pinfinder the other day its working , but yesterday when i use it . the screen appear like this until now:
Initializing...
software version: 1.23
Dongle S/N:
Dongle firmware version: 0116
Initializing PinFinder...
Initializing database...
base/user database version: 01/01
Loading configuration...
Initializing cable list...
Initializing platforms...
Initialization finished
searching adapter at COM5 (115200)...
too many retries
too many retries
too many retries
can't find adapter
searching adapter at COM1 (115200)...
warning: command confirmation absent
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
done
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
done
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
done
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
done
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
too many retries
too many retries
too many retries
can't find adapter
done
Old 08-16-2010, 09:02   #2 (permalink)
Member: 779599
Thanks Meter: 59
infinity team pls help how could i really know whether my infinity box is ok or my pinfinder is ok cause i try to format the phone with correct pin out but the box dont work , which really the problem my box or the pinfinder
Old 08-16-2010, 11:15   #3 (permalink)
Member: 779599
Thanks Meter: 59
i buy my box three months from now kindly give some idea on how to solve this problem
Old 08-16-2010, 21:42   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
check in device manager if your infinity box hold comport number 5
Old 08-17-2010, 05:29   #5 (permalink)
Member: 779599
Thanks Meter: 59
i already check the ports the infinity box hold it , i also uninstall the port driver and reinstall again but still dont work pls help me
Old 08-17-2010, 05:32   #6 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
check rj45 first pin 5v
if this volt absent no detect pinfinder.
pinout
1---5v+postive
2---rx
3---tx
4---na
5---na
6---na
7---negative
8---negative
The Following User Says Thank You to Imrankhan For This Useful Post:
Old 08-17-2010, 05:41   #7 (permalink)
Member: 779599
Thanks Meter: 59
i directly check the box by formating china phone using rj45 cable rx tx without pinfinder but the box dont work even i hold and press the power botton , i try to use the other software the phone run but in infinity box it does not work
COM5 [VCP0] selected
module v3.07
Action: reset settings ("format ffs")
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Old 08-17-2010, 05:57   #8 (permalink)
Member: 779599
Thanks Meter: 59
i open finder software i check the cable wire connected to the box of infinity with out connecting to the pinfinder box
this is the result
pinout
1-----------5v
2-----------rx 5v
3-----------tx 3.8
4-------------na
5------------na
6------------na
7------------negative
8------------negative
so now wheres the problem may there is a problem in infinity box cause even i directly conect the phone to the infinity box i doesnt work
module v3.07
Old 08-17-2010, 19:46   #9 (permalink)
Member: 148515
hello!
if you cant make phone formatted even without pinfinder- this means that this isn't pinfinder problem. you must continue check main infinity box.
check if switches is ok etc
if still nothing- you need to buy new unibox
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.22706 seconds with 9 queries
