09-10-2009, 00:58 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Ecuador
Member: 378918 Status: Offline Thanks Meter: 26 | Help please with my PinFinder ????? Press and hold phone power button nowsoftware version: 1.19 cable type: 1x5 (L5A) platform: MT: MT62xx (autodetect) searching adapter at COM77... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 11 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") |
09-10-2009, 01:39 | #2 (permalink) | |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | Quote:
in my opinion that. i seldom find rxtxgnd. sometimes rxtxgnd is in handsfree. br aswancamel | |
09-10-2009, 01:52 | #3 (permalink) |
Member: 378918 Status: Offline Thanks Meter: 26 | hi friend thanks for answering, I'm looking for the pin with PinFinder, the cable that remains for example the L14D or L12D, or L10A, but I try all these but I fail to read the phone, I hope I can yaudar a little more please ........ |
09-10-2009, 12:41 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! before searching pinout you must do 3 easy steps: 1. Make sure that this is mt62xx MCU based phone. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. Now activate Silent mode in phone by pressing and holding "#". 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if it does not turn On- no point to search for pinouts. you will not find it. Start from modifying your main infinity box to deliver more power to pinfinder. There is one diode which must be removed and shortcutted. Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done. after you get phone powered- you are ready to find phone pinout. press and Hold phone power button and start search. |
09-10-2009, 16:02 | #5 (permalink) |
Member: 378918 Status: Offline Thanks Meter: 26 | Hello friend thanks for reply, I commented that the phone will not start completely when I connect the cables, the logo comes up and restarts there, now you tell me you open the box to make changes, but opening it is assumed that the box loses the collateral and the box is really new in the recent purchase with the PinFinder ipmart, now I have another question, according to the manual I see that the cable going to the phone connects directly to the PinFinder, but in my case I leaves and first connect directly connected to a cable with reference PinFinder Infinity HDR26 M TO M "do not know if this has something to do or if either the connections, that thing you want to do is open the box to leave this as last resort, otherwise the manual says to check the output voltage rj45, in my case the voltage of versality of the infinity in which he says is USB and 4.78V which is 5.03V says com1, I hope I help as quickly as possible with my concerns please ......... |
09-11-2009, 22:04 | #7 (permalink) |
Member: 378918 Status: Offline Thanks Meter: 26 | Thanks friend, I finally cone hese Chinese phone, I expect no problems with management, anyway being upset about anything here, greetings from Cuenca, Ecuador. |
help please with my sagem my15ox unlock and go off | ehab tabshy | FuriousGold | 15 | 12-12-2009 08:43 |
HELP with my HUG Q-23 can't find with my pinfinder! | jaye_patok | Infinity-Box | 8 | 02-01-2009 17:51 |
problem with my pinfinder | EMOTION BBSR | Infinity-Box | 4 | 11-19-2008 16:52 |
Help please, with my nokia 6280 comprehension | yhanany | Nokia Base Band 5 ( BB-5 ) | 1 | 11-25-2006 16:32 |
please please please help me with my C350 | EssO | Motorola P2k | 12 | 02-27-2004 13:52 |
