08-27-2009, 00:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | How to calibrate the touchscreen Often we formatted devices (chinese miracle) at infinity and at the end he is calling to calibrate the touchscreen, but the touch escreen it is damaged and could have to calibrate the device is locked on that screen! I am posting the procedure so that everyone can understand and enjoy the service that the Team has given us infinity! 1°-Find pinning your phone 2°-Click the option SERVICE 3°Read FullFlash 4° After save BECKUP, click on the Repair tab. 5°Now Click Calibrate Touchscreen 6°The program will ask you if the BECKUP. click YES and indicates the location where you saved the Beckup! 7°Press and hold the power to start the process, Release when the program send and wait to finish the process! Oks!Your phone now not asked to calibrate more Toouchscreen: for the program of infinity Copies exactly this part of BECKUP and rewrites the device, thus avoiding the application of calibration in the home screen! I hope it helped! <---------------------------------------------------------------> If this post was helpful, click on thank! pesquisar |
The Following 46 Users Say Thank You to Bruno Rafael For This Useful Post: |
10-07-2009, 15:46 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | It doesn't work . COM4 [VCP0] selected module v2.93 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... Gabi_E307_JQ1_E307_GPRS_MT6225_S00.00_2__fullflash _20091007-172612.B0M.bin loaded Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5903:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E880_EVTST.01.0_25S00 Version: EVEN25_HW 44 byte(s) read imei: 35755600092547 connection Ok 512 byte(s) read 163 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! And still asking for calibration ... |
The Following 5 Users Say Thank You to usernome For This Useful Post: |
10-07-2009, 17:18 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | old method work good i am still using version 2.76 working fine for me new exe too much waste of time its my thinking br |
The Following 5 Users Say Thank You to c_ahmad79 For This Useful Post: |
10-08-2009, 05:54 | #5 (permalink) |
Freak Poster Join Date: Jul 2005 Location: pondicherry,INDIA Age: 47
Member: 165982 Status: Offline Thanks Meter: 71 | i am using latest version if touch is good,and if touch broken ,i am using old version to calibrate |
The Following User Says Thank You to barani For This Useful Post: |
10-08-2009, 13:48 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | I have a phone here in Traditional Chinese assistance that does not accept the touch scream .A touch the screen is perfect and it vibrates when the screen is touched. After a repair FS Complete it asks to calibrate the screen, but does not accept calibração.when touched the screen vibrates. When do the procedure of his friend Bruno Rafael the phone also does not touch the screen. Is there any way to repair this defect? |
The Following User Says Thank You to daroas For This Useful Post: |
10-08-2009, 16:07 | #8 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 48
Member: 184973 Status: Offline Thanks Meter: 27 | yes old method and software is working good,new chinese miracle waste allot of time without success mostly for the phones with startup tones,in short chinese miracle fails to repair touchscreen callibration |
10-14-2009, 19:51 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
please upload thid firmware to "www.rapidsahre.com" post here link, we will check what is wrong and make improvments | |
10-14-2009, 19:53 | #10 (permalink) | |
if old method is working for you better- you can still use old CM module for this operation. If you have some firmwares which is not supported by new method- please send to us, we will check them and make improvements. better if you upload them to "www.rapidshare.com" and post here links | |
10-14-2009, 19:54 | #11 (permalink) | |
can you find same working phone on local market? taking good working backup could help to flash your faulty phone | |
10-20-2009, 07:00 | #13 (permalink) | |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Quote:
10-20-2009, 11:32 | #14 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | COM3 [VCP2] selected module v2.94 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... D78_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V1_20 __fullflash_20090807-112215.B0M.bin loaded Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 00318E1:17F4 status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 82 sec Remove/Install battery now ! please solution???????? |
Not clear calibrate the touchscreen of this phone.Model Wi-Fi N2 | hussainafridi | Infinity-Box | 11 | 01-05-2010 07:32 |
how to bypass the spd calibration?? | peter002 | Infinity-Box | 2 | 10-09-2008 22:08 |
Help how to disable the Pen Calibration of N95 Single sim | Dj King | Infinity-Box | 6 | 08-09-2008 22:56 |
M55 How to calibrate battery | Yovcho | E-Gold Based Phones | 2 | 06-26-2004 01:10 |
How to calibrate battery in old motorola? | VELCOM BY | Motorola Old Legacy (EMMI) | 1 | 04-21-2003 20:55 |
