10-22-2009, 17:54 | #16 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
10-23-2009, 04:02 | #17 (permalink) |
Junior Member Join Date: Jan 2007
Member: 440050 Status: Offline Thanks Meter: 1 | infinity team can you please help me i try this solution but it shows COM5 [VCP0] selected module v2.95 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.CBM16B_H_V3 23__fullflash_20091023-095414.B0M.bin loaded Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8803:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 67 byte(s) read connection lost error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! |
10-23-2009, 04:05 | #18 (permalink) |
Member: 440050 Status: Offline Thanks Meter: 1 | problem solve i just retry the procedure COM5 [VCP0] selected module v2.95 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.CBM16B_H_V3 23__fullflash_20091023-095414.B0M.bin loaded Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8803:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: CBM16B_H_V323 Version: Celltel25_GEMINI_HW 67 byte(s) read imei: 35877402000415 connection Ok 512 byte(s) read 209 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 10 sec Remove/Install battery now ! thanks infinity team for this useful post |
10-29-2009, 13:53 | #19 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | Hi,i have one chinese were with TS problem. When you press up and down when pressing down does not work. I've tried all ways to fix both the newer software as in old 2.76 but no sucess. See down log the 2 software Quote:
10-31-2009, 18:25 | #20 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Ecuador/Android
Member: 1001831 Status: Offline Sonork: 100.1594557 Thanks Meter: 1,405 | Do you have full flash backup ? Cargando Archivo v.02... TL_M629_P42U06F09LO5_01_52__fullflash_20091031-120150.B0M.bin loaded Modelo: Autodetect 6205-6227 NOR Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6225:8A05:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:1403:000A status: FF Connecting at 19200, wait... error: can not finalize test mode Repita la Operacion y mantenga Oprimido el boton Power por un poco mas de tiempo ! error: La operación falló ! Finalizado, tiempo usado: 82 sec Quite/coloque la bateria ahora ! |
11-02-2009, 18:43 | #21 (permalink) | |
this program option do not repair touchscreen. it just makes phone bypass calibration after format. so if you touchscreen working not correctly- go to phone settings and do "manual" calibration | |
11-02-2009, 18:44 | #22 (permalink) | |
do you use pinfinder? | |
11-05-2009, 21:15 | #24 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! had you remove diode in main infinity box, as it is described in infinity pinfinder user manual? that diode is limiting output voltage of pinfinder which is not letting phone to be powered On completely |
11-19-2009, 21:58 | #25 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @all Just want to inform you, that latest "ChineseMiracle" software versions has both (old and new) calibration methods, so you can use old (fast but less stable) method or new (more slow, but more stable) method. |
12-08-2009, 22:45 | #27 (permalink) |
Freak Poster Join Date: Feb 2006 Location: INDIA
Member: 237007 Status: Offline Thanks Meter: 75 | 1°-Find pinning your phone 2°-Click the option SERVICE 3°Read FullFlash 4° After save BECKUP, click on the Repair tab. 5°Now Click Calibrate Touchscreen 6°The program will ask you if the BECKUP. click YES and indicates the location where you saved the Beckup! 7°Press and hold the power to start the process, Release when the program send and wait to finish the process! Its very useful post thank Br |
12-09-2009, 06:20 | #28 (permalink) | |
No Life Poster Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks Meter: 114 | Quote:
i have change version 2.87 but same problem plz help me what's problem | |
12-09-2009, 06:21 | #29 (permalink) |
Member: 1015645 Status: Offline Thanks Meter: 114 | module v3.02 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... BB13_PCB01_GPRS_MT6225_S00.BB13_BLE_L7EN_208_08050 9_HRILI9320_SIV0_TO75_CTF_BT_FM__fullflash_2009120 9-100029.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3103:0000 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 20 sec Remove/Install battery now ! |
Not clear calibrate the touchscreen of this phone.Model Wi-Fi N2 | hussainafridi | Infinity-Box | 11 | 01-05-2010 07:32 |
how to bypass the spd calibration?? | peter002 | Infinity-Box | 2 | 10-09-2008 22:08 |
Help how to disable the Pen Calibration of N95 Single sim | Dj King | Infinity-Box | 6 | 08-09-2008 22:56 |
M55 How to calibrate battery | Yovcho | E-Gold Based Phones | 2 | 06-26-2004 01:10 |
How to calibrate battery in old motorola? | VELCOM BY | Motorola Old Legacy (EMMI) | 1 | 04-21-2003 20:55 |
