07-18-2008, 19:06 | #1 (permalink) |
Junior Member Join Date: Dec 2006 Location: INDIA
Member: 419417 Status: Offline Thanks Meter: 7 | Infinity Box Not Rebuild Imei?????????? Right now i have Moto C168 IMEI is blank i tried to rebuild imei, software shows imei rebuid but in actual it's nothing is big problem when infinity TEAM work on this.........????? |
07-18-2008, 22:06 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Probably you will be surpriced, but we are able to read even very small size letter. As about c168 imei rebuild: you must make "search" in this forum before talk about software problems. If you unable to make search try to think about one easy thing: if your phone is damaged why not use repair eeprom before imei rebuild procedure There is no any problems with software, there is a problems with incorrect software usage ! |
08-21-2008, 09:06 | #3 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M JUST download this file from support n flash n u have working fone completely with its original IMEI,,,,BR PROCEDURE STEP BY STEP go to"Flash" page: "Firmware (code)": checked "File system" : un-checked "Alchemy data" : un-checked "Eeprom" : un-checked Load full flash file via "Load Firmware (code)"button "Format FFS" : un-checked "Smart write" : checked "Keep calibration area" : un-checked then press write n wait till end...BR | |
08-21-2008, 15:52 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yes, it's true, we have full flash file in Infinity-Box support area for repair purposes and also instruction exist in support area. |
infinity box not working plz help infinity team | Y2ksalman | Infinity-Box | 21 | 01-18-2011 00:51 |
lg mg 110 infinity box can't repair imei | devil6684 | Infinity-Box | 2 | 04-09-2009 16:48 |
LG KG800 can not rebuild IMEI | hsyuhang | Multi-Box | 5 | 11-28-2008 16:26 |
infinity box not repair imei funtion not in modulo? | landk | Infinity-Box | 2 | 11-21-2008 15:37 |
dream box cx65 rebuild imei? | kaaniletisim | DreamBox | 4 | 09-14-2006 11:43 |
