10-22-2022, 16:59 | #16 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Code: Operation: Reset Settings/Format FS [ v2.38 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] [+] Sensitive Data Backup Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: USB Serial Device (COM7) MODE: BOOTROM PORT: 7 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: CE0AC78337CFD2A7E45B0AC93BDDEB64 BROM: SecLevel: 0x000000E1 BROM: SecMode : SBC+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 6D5BBA224DA39B9FD727895BE5B0300BA5A20CADD33D979C88C5BC7CBF41358B Strange preloader structure 0x000C AGENT: 0_base : BASE_v1712 | Manual : Enabled AGENT: Looking for suitable BootChain in DA... AGENT: [63196b62] C:\Users\mess\Desktop\Symphony Z35 DA File\Symphony_Z35_DA_File.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 7001005458323936348A1E990829C70D EMMC: VEN: Kingston : OEM: 0 : ID: 545832393634 : PRV: 0x8A EMMC: VEN: Kingston : TX2964 EMMC: SNN: 513345577 ( 0x1E990829 ) MF: 12/2020 DA: EMI: Failed to get EMI info from selected source DA: EMI: EMI NUM is non-zero! Revert it back to 0 EMI: INFINITY PRELOADER_INFINITY_0 with 8 memory type(s) supported EMI: Init EMI from INTERNAL DB DA: SETUP EMI PARAMS FAILED ERROR: ABORT Boot done (1) EMI: 5 => 6 Done: 00:00:39 Reconnect Power/Cable now Done: 00:00:50 Code: Operation : Memory Tool Init [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : Symphony_Z35_DA_File.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : USB Serial Device (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : CE0AC78337CFD2A7E45B0AC93BDDEB64 BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6D5BBA224DA39B9FD727895BE5B0300BA5A20CADD33D979C88C5BC7CBF41358B BROM : EMI : Search BROM : EMI : Found! AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : Symphony_Z35_DA_File.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 7001005458323936348A1E990829C70D EMMC: VEN : KINGSTON : OEM : 0 : ID : 545832393634 : PRV : 0x8A EMMC: VEN : KINGSTON : TX2964 EMMC: SNN : 513345577 ( 0x1E990829 ) , MF : 12/2020 EMI : DEV : FireFly EMI : SRC : preloader_v755.bin EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 7001005458323936348A1E990829C70D EMMC: VEN : KINGSTON : OEM : 0 : ID : 545832393634 : PRV : 0x8A EMMC: VEN : KINGSTON : TX2964 EMMC: SNN : 513345577 ( 0x1E990829 ) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE92800000 [ 58.29 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4FFFAB9DB4DBB2E8B337E4902FB28633 DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Close MemoryTool session Done! Elapsed: 00:00:57 Reconnect Power/Cable! |
The Following User Says Thank You to mbiborna For This Useful Post: |
10-22-2022, 20:40 | #17 (permalink) | |
Anyway we wlil check it. | |
