Old 01-30-2020, 07:50   #196 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by debeliamark View Post
I have this tablet from a friend. Come with dead eMMC. Replaced with new one. Before to solder it on PCB filled via Z3x jTAG by write by vendor and selected Mediatek and files currently at CM2 [ official firmware extracted ]. Anyway - do not power on. Now try via cable, but cannot achieve success to revive it:
Card found : 0714xxx4 , v0138
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.07
Load IDBase v124106 Ok!
Preloader [HW DEV] Info :
 EMI : DEV : MT8163
 EMI : SRC : preloader_neostra8163_tb_m.bin
 EMI : CNT : 0001
 EMI : [00] : DRAM : LP_DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 512,00 MB ]
Operation : Write Flash [ v2.07 ]
Repartition   : Enabled
Flash Verify  : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW  : Enabled
SData Backup  : Disabled
Safe UserData : Disabled
Flash Format  : Disabled
Files :11
[FL] : Set : preloader_neostra8163_tb_m.bin
[FL] : Set : lk-sign.bin
[FL] : Set : boot-sign.img
[FL] : Set : recovery-sign.img
[FL] : Set : secro-sign.img
[FL] : Set : logo-sign.bin
[FL] : Set : tz-sign.img
[FL] : Set : system-sign.img
[FL] : Set : cache-sign.img
[FL] : Set : userdata-sign.img
[FL] : Total size : 0xC404B070 [ 3,06 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM13)
MODE : PRELOADER PORT
PORT : 13
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode  : SBC
BROM : PRELOADER PORT
MODE : Acer : A3-A40_[A6002] | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_SWSEC_A10H.bin
AGENT : Found MT8163
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 4D00017033353235A40053328B24483F
DAInf: 4 : 2 : 151
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERROR : 000000A5 :
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
I miss something, but... what?
We still didnt get any MT8163 eMMC sample to fix that. Made some changes in mtv208, but have no idea what will be a result.
Will upload in near two days.
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-30-2020, 09:23   #197 (permalink)
Member: 2301015
Sonork: 100.1668279
Thanks Meter: 10
Serial No: 8F5737E0 my dongal old versions only working . spd. mtk . ast all old versions only. team can't fix. format computer change computer virus guard stop 4-5 computer change . not working . infinity best working perfect . other all dongal box working . team email send but can't team fix. team my fault always repeated . but new pc format computer its working but not working . new activate buy. not any do this. my money lost and go time 1year activate . this can't fix refund please .
Old 01-30-2020, 14:26   #198 (permalink)
Member: 1772887
thank u for the update however cm2mt2 & cm2sp2 not work. although other interfaces are working
Old 02-12-2020, 16:34   #199 (permalink)
Member: 70259
Thanks Meter: 53
cm2mt2 & cm2sp2 not open
after make last update can not open those 2 soft. all other soft work fine
need help to make work again CM2MT2 AND CM2SP2.
PS FLEXY HUB not install try into 3 pc same
thanks
File Type: jpeg WhatsApp Image 2020-02-12 at 15.23.18.jpeg (29.4 KB, 6 views)
Old 02-13-2020, 10:42   #200 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
Any solution for this model sir Mi play Mi M1901F9E
Operation : Identify [ v2.07 ]
PTFN : MediaTek USB Port (COM64)
MODE : BOOTROM
PORT : 64
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+ARB
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001]
BROM : SOCID : 51E8055A9C5D9C2BDC897214F87662BE10A9AC9966CB720B11 4E0EABDCAE6A4D
AGENT : MTK_AllInOne_DA.bin
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
Old 02-13-2020, 10:49   #201 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
This is another info Sir..
MODE : BOOTROM
PORT : 64
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
MODE : 0_base : BASE_v1924 | Manual : Disabled
AGENT : Found MT6765
BROM : 0x00000001 : DA SEND ERROR!
ERROR : BROM : DL MODE ERROR
INFO : BROM Level : SLA AUTH or AUTH required!
Need DA and auth file.......
Old 02-22-2020, 20:24   #202 (permalink)
sharif_tell's Avatar
Member: 789364
Sonork: 100.1585484
Thanks Meter: 191
need support for mt6761 cpu. how about this.
Old 02-25-2020, 08:13   #203 (permalink)
JayDi's Avatar
Member: 462970
MODE : BOOTROM
PORT : 64
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SOCID : 51E8055A9C5D9C2BDC897214F87662BE10A9AC9966CB720B114E0EABDCAE6A4D
MODE : BOOTROM
PORT : 64
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
It is same phone.
Xiaomi require account to flashing from this device, or service ones and NO mi-cloud lost status.
Old 02-25-2020, 22:30   #204 (permalink)
Member: 148515
Thanks Meter: 19,534
New version CM2MT2 v2.08 released https://www.infinity-box.com/support/?r=100102
Old 03-04-2020, 09:29   #205 (permalink)
Member: 2584069
Thanks Meter: 4
just renew my cm2 activation yesterday. nice update always
Page generated in 0.17503 seconds with 9 queries
