10-14-2020, 03:57 | #46 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Xioami mi play mtk flas Thanks |
10-14-2020, 07:33 | #52 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
5-6-7, some 8 from first revisions will be. 9-10 are protected and will not work in 99.9% cases, maybe just some ugly chinese vault-made devices from old SDK's. | ||
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
10-14-2020, 15:54 | #54 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Yes you are right, Infnity CM2QLM is perfect tool and it really works in compare with many other tools. As you can read in current thread other users also agree with you that CM2QLM is very good and you can see programmers answer about QLM. Probably you missed th answer so let me qote it - programmers has veryy important research right now and as soon as this vry important reaserswill be finished they look at CM2QLM. |
10-14-2020, 15:56 | #55 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Thank you very much for your copy/past question ! Great job ! Please let me make copy/past of the previous answer too. Yes you are right, Infnity CM2QLM is perfect tool and it really works in compare with many other tools. As you can read in current thread other users also agree with you that CM2QLM is very good and you can see programmers answer about QLM. Probably you missed th answer so let me qote it - programmers has veryy important research right now and as soon as this vry important reaserswill be finished they look at CM2QLM. Thank you for your reminder, we are really proud to see that CM2QLM is very popular and that CM2QLM is so important for Infinity users ! Work is in prigress ! |
10-14-2020, 15:59 | #56 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
I am not sure but it looks like this opton require server access. At least there is no any info about this function in current release text. I am sure development team know much more and work step-by-step. | |
10-15-2020, 02:38 | #58 (permalink) |
Registered User Join Date: Feb 2016
Member: 2530239 Status: Offline Thanks Meter: 14 | Card found : DD311855 , v0145 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.16 Load IDBase v729152 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_h920bk_v1_g_spsj_s06s_iq.bin EMI : CNT : 0003 EMI : [00] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [02] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.16 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :12 [FL] : Set : preloader_h920bk_v1_g_spsj_s06s_iq.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : teksunhw.bin [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x4454356F [ 1.07 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM1094) MODE : PRELOADER PORT PORT : 1094 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
