Old 01-24-2021, 17:06   #136 (permalink)
sajidi1984's Avatar
Member: 2778467
Sonork: only Telegram
Thanks Meter: 265
I can't express my happiness in words You made the impossible possible Big Thanx To You
Old 01-24-2021, 17:06   #137 (permalink)
SkyCleaner's Avatar
Member: 2697846
Thanks Meter: 77
Originally Posted by amrMHF View Post
flash Eng firmware xiaomi redmi 6a Done!!
Operation : Write Flash [ v2.17 ]
Repartition   : Enabled
Flash Verify  : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW  : Enabled
SData Backup  : Disabled
Safe UserData : Disabled
Flash Format  : Disabled
Files :22
[FL] : Set : preloader_cereus.bin
[FL] : Set : recovery.img
[FL] : Set : efuse.img
[FL] : Set : md1img.img
[FL] : Set : spmfw.img
[FL] : Set : scp.img
[FL] : Set : sspm.img
[FL] : Set : vbmeta.img
[FL] : Set : lk.img
[FL] : Set : lk.img
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : odmdtbo.img
[FL] : Set : cust.img
[FL] : Set : tee.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x6445FF64 [ 1.57 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM22)
MODE : BOOTROM
PORT : 22
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
     TYPE : MODERN RAPHAEL
BROM : MEID : 517D1D5C304E3A8429EC998903C929E6
BROM : SecLevel : 0x000000E7
BROM : SecMode  : SBC+SLA+SDA+EXT
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
MODE : Xiaomi : 6A | Manual : Disabled
BROM : SOCID : 9E831993CB579BD5554C09C82A627CA048698099CA6E5674537D82C899134E0D
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : MT6765
     EMI : SRC : preloader_cereus.bin
     EMI : CNT : 000A
 EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX     | DEV : HBG4a2 : RAM : [ 3.00 GB ]
 EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX     | DEV : hB8aP> : RAM : [ 3.00 GB ]
 EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX     | DEV : HAG4a2 : RAM : [ 2.00 GB ]
 EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON    | DEV : S0J9B7 : RAM : [ 3.00 GB ]
 EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG   | DEV : QE63MB : RAM : [ 2.00 GB ]
 EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG   | DEV : GD6BMB : RAM : [ 3.00 GB ]
 EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON    | DEV : S0J9A7 : RAM : [ 2.00 GB ]
 EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG   | DEV : RH64AB : RAM : [ 4.00 GB ]
 EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX     | DEV : HCG8a4 : RAM : [ 4.00 GB ]
 EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG   | DEV : QD63MB : RAM : [ 2.00 GB ]
     EMI : Init EMI from PRELOADER
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00038000 [ 224.00 KB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        EMMC: 150100514536334D4203E2AFC6A67571
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3A3E00000 [ 14.56 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 2DBA6136C6ED71CF8166CD6A78880B57
DA : USB : HIGH-SPEED
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000005688000
Erase : 0x0000000007688000 : 0x0000000006000000
Erase : 0x000000000E800000 : 0x0000000004A00000
Erase : 0x0000000013500000 : 0x0000000008980000
Erase : 0x000000001FE80000 : 0x00000001CB180000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : EFUSE
Write : MD1IMG
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : VBMETA
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : ODMDTBO
Write : CUST
FAIL : SEC : IMG TYPE MISMATCH
Write : TEE1
Write : TEE2
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
Ultra : Ok!
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:01:51
Reconnect Power/Cable!
Did you manually selected preloader on SW OR where could i be doing wrong. Have save set on hand
Old 01-24-2021, 17:14   #138 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 453
Lightbulb
unbelievable great work
Old 01-24-2021, 17:21   #139 (permalink)
aymandh4's Avatar
Member: 2529545
Sonork: aymandh4
Thanks Meter: 68
Operation : Identify [ v2.17 ]
Mode : FLASH
PTFN : MediaTek USB Port (COM35)
MODE : BOOTROM
PORT : 35
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : 1F90F193B78439FE2586CEB087263C33
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Disabled
BROM : SOCID : 6522217C65EE61271AC79735FC27004C0CE7E4EFF979399144 60CE5B7CDF4CFB
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0008
EMI : Init EMI from INTERNAL DB
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Error : Fail to init protocol!
>>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
EMI : DEV : MT6765
EMI : SRC : preloader_oppo6762_18540.bin
EMI : CNT : 0009
EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ]
EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ]
EMI : [05] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ]
EMI : [06] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4,00 GB ]
EMI : [07] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ]
EMI : [08] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ]
Mode : FLASH
MODE : BOOTROM
PORT : 35
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Enabled
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : CNT : 0009
SRAM: 0x0003A000 [ 232,00 KB ]
DRAM: 0x80000000 [ 2,00 GB ]
EMMC: 150100514436334D4203946ECE9F2623
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x01000000 [ 16,00 MB ]
USER : 0x747C00000 [ 29,12 GB ]
RNID : 7FA7F2BE48C7077C21093B35D0D3D6D3
Boot done!
Patch Level : PPR1.180610.011
Ver. CodeName : REL
Ver. Release : 9
Sec. Patch : 2020-07-05
Product Manfct : OPPO
Build Time : 25.07.2020
Product Brand : OPPO
Product Model : CPH1923
Product Info : CPH1923
Product Name : CPH1923
Product Device : OP486C
SW OTA Version : CPH1923EX_11.A.33_0330_202007252320
Display ID : CPH1923EX_11_A.33
Kernel Info : 4.9.117
USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption )
NVRAM check : Passed!
NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ]
Backup sensetive data [ 11 ]
Backup path : Backup\MT6765__7FA7F2BE48C7077C21093B35D0D3D6D3\
[29] Read : NVRAM
[13] Read : NVDATA
[20] Read : PROINFO
[30] Read : LK
[12] Read : NVCFG
[15] Read : PROTECT1
[16] Read : PROTECT2
[18] Read : PERSIST
[0] Read : PRELOADER
[17] Read : SECCFG
Backup done!
STORAGE : LifeStatus : eMMC : OK!
Done!
Elapsed: 00:00:37
The Following 4 Users Say Thank You to aymandh4 For This Useful Post:
Old 01-24-2021, 17:24   #140 (permalink)
Registered User
Member: 2381725
Thanks Meter: 126
Good update súper súper update, great work team!!!
Old 01-24-2021, 17:35   #141 (permalink)
Crazy Poster
Member: 2658715
Thanks Meter: 12
Wooh
Sent from my iPhone using Tapatalk
Old 01-24-2021, 17:44   #142 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 907
you must select model and use volume keys to boot phone
The Following User Says Thank You to amrMHF For This Useful Post:
Old 01-24-2021, 17:52   #143 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by nori2007 View Post
oppo a31 read fLASH
Update configuration ...
Update Ok!
Load IDBase v124161 Ok!
Operation : Read Firmware [ v2.17 ]
ExtSparse   : Enabled
ForceRead   : Disabled
PTFN : MediaTek USB Port_V1632 (COM3)
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : MEID : 0898E64F2B299AC146FDAD07A62F4AA1
BROM : BOOTROM
BROM : SOCID : CE05BD02FF1448C6EDA80272AF8C6547C4D0ECFC644C7EFD89935C9386F7280C
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        SRAM: 0x0003A000 [ 232.00 KB ]
        DRAM: 0x100000000 [ 4.00 GB ]
        EMMC: 1501004448364441420293627764771
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DAB
        EMMC:
              RPMB   : 0x01000000 [ 16.00 MB ]
              USER   : 0xE8F800000 [ 58.24 GB ]
        RNID : 912AF7FC11D9547224AB3EA59317F4DD
Boot done!
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2021-01-05
Build Time     : 17.12.2020
Product Model  : CPH2015
Product Info   : CPH2015
Product Name   : CPH2015
Product Device : OP4C7D
SW OTA Version : CPH2015PUEX_11.A.49_0490_202012172145
Display ID     : CPH2015EX_11_A.49
Display ID     : CPH2015EX_11_A.49_201217
MT6765__OPPO__CPH2015__9__CPH2015EX_11_A.49_201217__PPR1.180610.011__CPH2015
Unsupport : 0x0000000006988000 : 0x0000000004000000 : opporeserve3
Error : Device NOT supported for SAVE READ!
>>> Send log and report.log (if exists) to support! Include device info also!
Restart MT2 module and repeat once again.
Old 01-24-2021, 17:53   #144 (permalink)
Member: 1972033
Thanks Meter: 32
is that need any boot key or just connect usb cable ? nori2007
Old 01-24-2021, 17:55   #145 (permalink)
JayDi's Avatar
Member: 462970
Please, read post :
https://forum.gsmhosting.com/vbb/14313188-post6.html
Then this :
https://forum.gsmhosting.com/vbb/f29...vices-2941588/
Old 01-24-2021, 18:17   #146 (permalink)
Registered User
Member: 2506300
Thanks Meter: 345
whats wrong with me help me please
Old 01-24-2021, 18:29   #147 (permalink)
Member: 2108610
Thanks Meter: 379
I am wating for this update long time, so, many people wating for this word first, infinity team ss ordinary with unique solutions
Old 01-24-2021, 18:32   #148 (permalink)
Member: 1302942
Thanks Meter: 171
READ THIS POST, PLEASE.
https://forum.gsmhosting.com/vbb/14313807-post145.html
The Following User Says Thank You to fedja85 For This Useful Post:
Old 01-24-2021, 18:44   #149 (permalink)
Member: 2730213
Thanks Meter: 2
PTFN : MediaTek USB Port (COM25)
MODE : BOOTROM
PORT : 25
BROM : Init BROM
BROM init passed!
CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Krug
BROM : MEID : 684F479B6CAF7F0272D6FDFE74A98E50
BROM : BOOTROM
MODE : Xiaomi : Helio [G90][A22] | Manual : Disabled
BROM : SOCID : 82E34F9FAD8CAAC196FB03FD2827828A5AEC50F5069D8C65E2 D896C56BA4864F
AGENT : MTK_AllInOne_DA_V2.bin
AGENT : Found MT6785
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EMI : Failed to get EMI info from selected source!
Old 01-24-2021, 18:52   #150 (permalink)
Member: 1302942
Thanks Meter: 171
MODE : BOOTROM
PORT : 25
BROM : Init BROM
BROM init passed!
CODE : Krug
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
READ THIS POST
Page generated in 2.30047 seconds with 9 queries
