01-25-2021, 06:14 | #211 (permalink) | |
Major Poster Join Date: May 2009 Location: Indonesia
Member: 1039909 Status: Offline Thanks Meter: 14 | A1k smart reset failed ... Emi?? Quote: Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 6455F245F5E7BDFB8CC3909C0083B572 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 16B02DF43FFEF39D1D89253CF331A4F49ED3208DEB0AE85A48 B2D9C69DF7B321 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! how to fix error in EMI? | |
01-25-2021, 06:16 | #212 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | Oppo A1K Format FS Done Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 5562A90E28A960F7E5B5B5AB0B20C62B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 8D297724415FF1B5CF5D208A831369248C41544D7C32E4D9B9 BADA072CFABB48 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420470339BF177B7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1A205BD2538752BFFB881F3C64C3AA6 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
01-25-2021, 06:26 | #215 (permalink) | |
Major Poster Join Date: Feb 2005 Location: India Age: 45
Member: 113231 Status: Offline Thanks Meter: 4 | how to? please explain step by step Quote:
01-25-2021, 07:04 | #220 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-25-2021, 07:07 | #221 (permalink) |
Major Poster Join Date: Feb 2018 Location: Bermuda Triangle
Member: 2809714 Status: Offline Thanks Meter: 22 | @Team Please Guide what i'm missing TIA Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM87) MODE : BOOTROM PORT : 87 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : F54FD8C44672FF0C525F069C368D93C9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : F5369AD75FAA21DAF3766F023045BAC461F55074F7A0B629C4 1C7100CD9CDDAA BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
01-25-2021, 07:28 | #223 (permalink) | |
01-25-2021, 07:29 | #224 (permalink) |
Freak Poster Join Date: Jan 2010 Location: PAKISTAN.MUZAFFAR GARH
Member: 1211191 Status: Offline Thanks Meter: 46 | Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 36CE450775D056AC46BE06CF32DA50ED BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 4DE6CE6E14752A2BE0F390320F1AACA48E097FCFA9354D987E 286935803280DF BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420334E56A8B37D3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5BD1450A510BD7532B0450BF357A60A DA : USB : HIGH-SPEED Boot done! Device PMT Info : PART : 0x0000000000000000 : 0x0000000000400000 : preloader PART : 0x0000000000000000 : 0x0000000000008000 : pgpt PART : 0x0000000000008000 : 0x0000000000100000 : boot_para PART : 0x0000000000108000 : 0x0000000002000000 : recovery PART : 0x0000000002108000 : 0x0000000000080000 : para PART : 0x0000000002188000 : 0x0000000000800000 : opporeserve1 PART : 0x0000000002988000 : 0x0000000004000000 : opporeserve2 PART : 0x0000000006988000 : 0x0000000004000000 : opporeserve3 PART : 0x000000000A988000 : 0x0000000000100000 : oppo_custom PART : 0x000000000AA88000 : 0x0000000001400000 : expdb PART : 0x000000000BE88000 : 0x0000000000100000 : frp PART : 0x000000000BF88000 : 0x0000000000800000 : vbmeta PART : 0x000000000C788000 : 0x0000000002000000 : nvcfg PART : 0x000000000E788000 : 0x0000000004000000 : nvdata PART : 0x0000000012788000 : 0x0000000002000000 : metadata PART : 0x0000000014788000 : 0x0000000000800000 : protect1 PART : 0x0000000014F88000 : 0x0000000000878000 : protect2 PART : 0x0000000015800000 : 0x0000000000800000 : seccfg PART : 0x0000000016000000 : 0x0000000003000000 : persist PART : 0x0000000019000000 : 0x0000000000200000 : sec1 PART : 0x0000000019200000 : 0x0000000000300000 : proinfo PART : 0x0000000019500000 : 0x0000000006400000 : md1img PART : 0x000000001F900000 : 0x0000000000100000 : spmfw PART : 0x000000001FA00000 : 0x0000000000100000 : scp1 PART : 0x000000001FB00000 : 0x0000000000100000 : scp2 PART : 0x000000001FC00000 : 0x0000000000100000 : sspm_1 PART : 0x000000001FD00000 : 0x0000000000100000 : sspm_2 PART : 0x000000001FE00000 : 0x0000000001000000 : gz1 PART : 0x0000000020E00000 : 0x0000000001000000 : gz2 PART : 0x0000000021E00000 : 0x0000000004000000 : nvram PART : 0x0000000025E00000 : 0x0000000000100000 : lk PART : 0x0000000025F00000 : 0x0000000000100000 : lk2 PART : 0x0000000026000000 : 0x0000000002000000 : boot PART : 0x0000000028000000 : 0x0000000001000000 : logo PART : 0x0000000029000000 : 0x0000000001000000 : dtbo PART : 0x000000002A000000 : 0x0000000000500000 : tee1 PART : 0x000000002A500000 : 0x0000000000B00000 : tee2 PART : 0x000000002B000000 : 0x0000000010000000 : odm PART : 0x000000003B000000 : 0x0000000039800000 : vendor PART : 0x0000000074800000 : 0x000000012C000000 : system PART : 0x00000001A0800000 : 0x000000001B000000 : cache PART : 0x00000001BB800000 : 0x00000005888FBE00 : userdata PART : 0x00000007440FBE00 : 0x0000000002B00000 : otp PART : 0x0000000746BFBE00 : 0x0000000001000000 : flashinfo PART : 0x0000000747BFBE00 : 0x0000000000004200 : sgpt Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-01-05 Product Manfct : OPPO Build Time : 21.12.2020 Product Brand : OPPO Product Model : CPH1923 Product Info : CPH1923 Product Name : CPH1923 Product Device : OP486C SW OTA Version : CPH1923EX_11.A.38_0380_202012211313 Display ID : CPH1923EX_11_A.38 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:01:09 Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET Info : Operation break by user! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 36CE450775D056AC46BE06CF32DA50ED BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 4DE6CE6E14752A2BE0F390320F1AACA48E097FCFA9354D987E 286935803280DF BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420334E56A8B37D3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5BD1450A510BD7532B0450BF357A60A DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
01-25-2021, 07:33 | #225 (permalink) |
Member: 113231 Status: Offline Thanks Meter: 4 | oppo a1k cph 1923 reset failed Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 29ED6443FF8BAD67A81898F63121317F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 47121CCEAA8023EA82992830FEFB9758658F141D7F69AAD575 C3B4182B68C9AB BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
