01-13-2017, 15:21 | #31 (permalink) |
Junior Member Join Date: Jan 2008
Member: 688301 Status: Offline Thanks Meter: 1 | |
01-13-2017, 15:22 | #32 (permalink) |
Freak Poster Join Date: Feb 2011 Location: cuba Age: 53
Member: 1524998 Status: Offline Thanks Meter: 76 | Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 04841F2B ID_BLOCK_I : 008140E1 ID_BLOCK_L : 83C9BFC22838A9C82928C73C03BDB837 ID_BLOCK_L : 0F15E49AB9DB67DF4E7F09E8ECCFCE33 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! zte z933 help |
01-13-2017, 17:11 | #34 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | |
01-13-2017, 17:39 | #35 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-13-2017, 17:39 | #36 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Can you make Identify log? Quote:
01-13-2017, 17:40 | #37 (permalink) | |
01-13-2017, 19:16 | #41 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Molakalmuru (KARNATAKA) {INDIA
Member: 1891452 Status: Offline Thanks Meter: 29 | Coolpad dazen 1 8297L_100 still not Support team please analyse it whats the problem is it really not support or i am doing mistake its working phone Card found : CF166680 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D0E6905 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 439052F44663EA003767955792CDF50F ID_BLOCK_L : 67AE193528BC6F653FBFF8AD56521507 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D0E6905 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 439052F44663EA003767955792CDF50F ID_BLOCK_L : 67AE193528BC6F653FBFF8AD56521507 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Last edited by Mohammed Farooq; 01-13-2017 at 19:23. |
The Following User Says Thank You to Mohammed Farooq For This Useful Post: |
01-13-2017, 20:18 | #43 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Sir did u check theard title it's Qualcomm theard plz post in right thread ,,, 7731c long time ago it's supported as ur talking abt some tool cm2 is far ahead of all tools just check if any error plz post logs Sent from my S_plus using Tapatalk | |
01-13-2017, 23:16 | #44 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Can you add selection windows for read/write when we select xml file? i mean sometimes we need just read/write some partitions like bootloader area or some other Thanks |
