Old 03-29-2017, 08:18   #136 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Originally Posted by JayDi View Post
It supported from a long time ago.
Use search for more info.
lot of mobile not support in this version
how much day later cm2 qlm update will release ?
Old 03-29-2017, 10:06   #137 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
If you can't handle it - then it not mean about "lot of mobiles not supported".
Make reports, post logs. It will better way for all.
Old 03-29-2017, 21:26   #138 (permalink)
Member: 1279406
Thanks Meter: 2
lyf wind 7 not working in Cm2 any idea how? its work
Sent from my CP8298_I00 using Tapatalk
Old 03-30-2017, 06:52   #139 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
ok i will make reports and post
what did you thinking something new in near time
everybody knows cm2 is ahed of all other product there no doubt about that
do you feel, are you proud as a infinity product manager ?
Old 03-30-2017, 16:39   #140 (permalink)
JayDi's Avatar
Member: 462970
Post logs. For start. Without them there is no way to help.
Old 03-31-2017, 13:05   #141 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by ASHIF View Post
when i run new qualcom 1.11 exe it says update firmware....previous version was running smoothly ....already updated firmware but still same
Box/Dongle Serial No (S/N): 0639DFF2
Firmware version: 0134.02
Hello,
What is your Support Validity Date ?
How to check - http://www.infinity-box.com/doc.php?id=17
If you have active support - run DongleManager software and update Box/Dongle firmware.
If support is not active - please contact to any seller and renew support.
Old 03-31-2017, 13:06   #142 (permalink)
Member: 1043909
Originally Posted by safajan View Post
my Qlm version is 1.11 now. i remeber i had been run it with 1.09 version.but in thi s new update i have this problem. thanks infinity team
Hello,
Old 03-31-2017, 13:10   #143 (permalink)
Member: 1043909
Originally Posted by hashamijan88 View Post
hi Cmtools team my Cmtool not opening lg and qulcomm exe what is the reason plz i need to ur help and information i waiting to ur reply and help
Hello,
Old 03-31-2017, 17:20   #144 (permalink)
WINDA's Avatar
Member: 804772
Thanks Meter: 129
do you not have fast link to download like mediafire or googledrive
Old 03-31-2017, 19:39   #145 (permalink)
Member: 1043909
There are 3 links in current thread first post.
Did you tried that ?
Old 03-31-2017, 20:01   #146 (permalink)
Member: 2478867
samsung gt i9082 copy mt6572
please help for this
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 150100534A533030410A53422B7E5FCD
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:21
Reconnect Power/Cable!
Old 03-31-2017, 20:07   #147 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
wait for phone...
Phone found! [ 12 ]
sync...
Inital boot ok!
Bb_cpu_pid : 6572
bb_cpu_nme : [mediatek] mt6572_s00
bb_cpu_ext : 0xca01 , 0x8a00 , 0x0000
processing brom stage
settings for brom configured!
Seccfgval : 0x00000000
bromver : 0x0005
blversion : 0x00fe
preloader : Not active [ erased ]
bootldrss : Normal with preloader
processing da stage
da select done, will use mtk_allinone_da_v5.1624.16.07
sending and initialize da ...
Running da ver.4.2 on bbid : 0x88
nand flash : Not installed
emmc flash : 150100534a533030410a53422b7e5fcd
initialize memory ...
[da_error] : Dram configure failed!
Errocode : 0x2003
emicfg_not_found
try not hold volume(+/-) keys on connect!
Boot error!
Operation failed
elapsed: 00:00:21
reconnect power/cable!
preloader active after read infarmation.
The Following User Says Thank You to nahidroman For This Useful Post:
Old 04-03-2017, 18:29   #148 (permalink)
Member: 1741973
Thanks Meter: 115
need firmware backup huawei G620S-L02 for caresuite emergency operation using CM2... tnx
Old 04-03-2017, 18:33   #149 (permalink)
Member: 1741973
Thanks Meter: 115
same problem with huawei y625-u43 QD Loader 9008 only in device manager
Originally Posted by vishal kapoor View Post
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : C388A0BF
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 988B4BC39CF07904A135C6B516198F30
ID_BLOCK_L : 8BCCA0542D5C13393043B535305FFBB9
Use CM2 Internal Loader
Error : Prepare target failed! Unsupported SecureType!
Send log and report.log to support! Include device info also!
oppo r9s cph1607
is this logs error cause by eMMC faulty or CM2 qualcom bugs?
Old 04-03-2017, 23:54   #150 (permalink)
Member: 2478867
welcom
same problem how to solve
Page generated in 0.22823 seconds with 8 queries
