11-10-2021, 08:47 | #107 (permalink) |
Crazy Poster Join Date: Jun 2021 Location: ATTOCK Pakistan Age: 39
Member: 2990669 Status: Offline Sonork: 100.1660561 Thanks Meter: 61 | itel Vision1 Plus P36 Pro LTE L6501, Reset Settings + FRP Identif Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : L6501-F6311-9.0-OP-V048-20210913 Ver. Incmt : OP-V048-20210913 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-09-05 Build Time : 13.09.2021 Product Model : itel L6501 Product Brand : Itel Product Name : F6311 Product Device : itel-L6501 Product Manfct : itel Product Info : L6501 Product Board : L6501 Board Platform : sp9863a Product Name : L6501 Product Device : L6501 Platform Version: MOCORTM_18B_ITEL_W19.28.5_P16_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_ITEL_W19.28.5_P16 HW Version: sc9863A_modem CMP_Time : 08-24-2021 01:37:58 MODEM TAG : MOCORTM_18B_ITEL_W19.28.5_P16_Debug_FM_BASE_18B_ITEL_W19.28.5_P16_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:14 Code: Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:15 |
The Following 5 Users Say Thank You to geo/mobile For This Useful Post: |
11-18-2021, 18:57 | #109 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | A1 Alpha / ZTE The phone A1 Alpha was so popular in 2019 like cheapest SP branded unit in Bulgaria / Belarus ect... The original one is ZTE xxx. The readout: Code: Operation : Read FW [ v2.13 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : A1_EU_P963F01V1.0.0B11_DL.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : A1_Alpha_EEA_B14 Ver. Incmt : 20200116.232039 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-01-05 Build Time : 16.01.2020 Product Model : A1 Alpha Product Brand : A1 Product Name : A1_AT_EEA_P963F01 Product Device : P963F01D Product Manfct : A1 Product Info : P963F01D Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : sprout Board Platform : sp9863a AndroidVer : 9 VlnrLevel : 0x02 SP9863A__A1__A1_Alpha__9__A1_Alpha_EEA_B14__PPR1.180610.011__P963F01D Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : dtb.img Read : dtbo.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : nvitem_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : system.img Read : vendor.img Read : otp_product.img ExtSparse : Compression ratio : 1% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 9% Read : deltanv_l.bin Read : phase.cfg Read : ztecfg.bin Read : ztepersist.bin ExtSparse : Compression ratio : 16% Read : u-boot-spl.bin Waiting for device ... ADB : Device found! ADB : Connected! ADB : Prepare Ok! Cookies! Wait for something to happen ... Mankind should survive Firmware size : 0x103EB6A6C ( 4,06 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:18:54 BR, DebeliaMark, BG |
The Following User Says Thank You to debeliamark For This Useful Post: |
11-18-2021, 20:31 | #110 (permalink) |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | hi Tank you infinity team for the support and new fetures pls tell as if there is a way to unlock service provider lock of spd 9832E XIAOMI QIN 1S+ thank you in advance ! |
11-23-2021, 11:16 | #112 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | iHunt Apex S20 Plus Readout There is a readout from strange phone, named iHunt APEX S20 Plus [ Same as Invens MAX 5 ]: Code: Device info : Patch Level : PPR1.180610.011 Display ID : J106E_iHunt_S20 Plus Apex_B18_12816_V1.0_20201102 Ver. Incmt : 43318 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-05 Build Time : 02.11.2020 Product Model : MAX5 Product Brand : Invens Product Name : MAX5 Product Device : MAX5 Product Manfct : Invens Product Info : MAX5 Product Board : sp7731e_1h10 Board Platform : sp7731e AndroidVer : 9 VlnrLevel : 0x02 BR, DebeliaMark, BG |
The Following 3 Users Say Thank You to debeliamark For This Useful Post: |
11-24-2021, 07:19 | #113 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 199340 Status: Offline Sonork: 100.1592925 Thanks Meter: 192 | Plum spd 7731 frp reset done Hi team log is here -------------------------------------- Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Z518_PLUM_V1.0_20180903 Ver. Incmt : 36114 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-08-05 Build Time : 03.09.2018 Product Model : Z518 Product Brand : PLUM Product Name : Z518 Product Device : Z518 Product Board : Z518 Product Manfct : TEM Product Info : sp7731e_fs286 Product Board : sp7731e_fs286 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.23.4_P5_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P5 HW Version: sc7731e_modem CMP_Time : 07-31-2018 11:14:32 MODEM TAG : MOCORTM_17C_W18.23.4_P5_Debug_FM_BASE_17C_W18.23.4 _P5_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:57 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:49 |
The Following 2 Users Say Thank You to mortal90210 For This Useful Post: |
11-25-2021, 19:21 | #114 (permalink) | |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Realme C21Y RMX3263 can't read info and any other operation always this can add in the next update? This device got Unisoc T612 CPU and is the same as T610 CPU just a little faster. Quote:
11-25-2021, 23:19 | #116 (permalink) | |
Member: 2771307 Status: Offline Thanks Meter: 772 | Yes, I try not work. Mean in realme tab is only RMX3231 or SC9863. I try boot like RMX3231 and not work too. Quote:
https://mega.nz/file/sr4lXQLL#zNd6PJ...0Mt_ho0lY79oX8 Last edited by IMEI_info; 11-25-2021 at 23:25. | |
11-27-2021, 17:39 | #118 (permalink) |
Insane Poster Join Date: Oct 2013 Location: Turkmenistan, Balkanabat
Member: 2044809 Status: Offline Thanks Meter: 11 | Hi Gents! Need your advice,I read firmware via spd2 and when i trying to flash it back i getint error UBOOT : u-boot-spl.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! this error i geting on most phone with normal emmc, so it means that i do smething wrong but what? |
11-27-2021, 17:55 | #119 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Also, you may try change working loader : Select FW, select in platform tab, from model list appropriate loader for device, try flash. What a result? | |
11-27-2021, 18:09 | #120 (permalink) |
Member: 2044809 Status: Offline Thanks Meter: 11 | Always problem with this "UBOOT : u-boot-spl.bin" file Its from last log 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! Prepare target ... Prepare Ok! UBOOT : u-boot.bin UBOOT : u-boot.bin CODE : sml.bin CODE : sml.bin CODE : tos.bin CODE : tos.bin CODE : vbmeta.img CODE : vbmeta.img CODE : pm_sys.bin CODE : modem_w.bin CODE : gdsp_w.bin CODE : modem_wcn.img CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : boot_logo.bmp CODE : fastboot_logo.bmp FSIMG : persist.img CODE : boot.img CODE : recovery.img FSIMG : system.img FSIMG : vendor.img FSIMG : userdata.img FSIMG : cache.img FSIMG : prodnv.img UBOOT : u-boot-spl.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! >>> Error : Flashing failed! >>> Check previous message for more info! Reconnect Power/Cable! |
