05-12-2017, 15:26 | #122 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | open dongle manager select "Set UK Edition off" and Process now open software you will find imei option thanks to you all bygsmzaman |
The Following User Says Thank You to muhammad khalid For This Useful Post: |
05-13-2017, 06:49 | #123 (permalink) |
Insane Poster Join Date: Dec 2008 Location: indonesia
Member: 924142 Status: Offline Thanks Meter: 12 | FIX SOLUTION MIRACLE CM2 TEAM === DongleManager [Infinity] v1.70 [05/13/2017 12:46:46] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00011CDF7D314082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D9XXXXXX Firmware version: 0135.02 === Process started: 05/13/2017 12:46:47 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
The Following User Says Thank You to nur khanif For This Useful Post: |
05-13-2017, 06:57 | #124 (permalink) |
No Life Poster Join Date: Jun 2011 Location: manila
Member: 1595088 Status: Offline Thanks Meter: 184 | Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
The Following User Says Thank You to tartcell18 For This Useful Post: |
05-13-2017, 07:01 | #125 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,353 | Quote:
05-13-2017, 07:57 | #126 (permalink) |
Insane Poster Join Date: Dec 2016 Location: pakistan
Member: 2661593 Status: Offline Thanks Meter: 15 | Team plz give sport for sc7701 &7702 chip or info for this Sent from my SM-G531H using Tapatalk |
The Following User Says Thank You to qaiserrehman For This Useful Post: |
05-13-2017, 14:22 | #128 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2588221 Status: Offline Thanks Meter: 1 | After upgrade dongle no Imei repair option please solve it INFINITY TEAM Sent from my vivo 1601 using Tapatalk |
The Following User Says Thank You to BALAJI9966 For This Useful Post: |
05-14-2017, 09:22 | #129 (permalink) |
Junior Member Join Date: Jan 2016 Location: Saudi Arabia Age: 37
Member: 2523603 Status: Offline Thanks Meter: 4 | great job............................................... ............... |
The Following User Says Thank You to Androidkake For This Useful Post: |
05-14-2017, 12:43 | #131 (permalink) |
Major Poster Join Date: Sep 2016
Member: 2629080 Status: Offline Thanks Meter: 19 | === DongleManager [Infinity] v1.70 [5/14/2017 16:10:04] === Box/Dongle type selected: [BEST] Card-Reader: USB CCID Smart Card Reader 0 HWID: 0108686120281292 Box/Dongle found: [BEST] Reading... Serial No (S/N): B34D6861 Firmware version: 0122.02 === Process started: 5/14/2017 16:10:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
The Following User Says Thank You to ..::AtifGsm::.. For This Useful Post: |
05-14-2017, 14:10 | #132 (permalink) |
Freak Poster Join Date: Jan 2012 Location: pakistan dubai
Member: 1711454 Status: Offline Sonork: 100.1605681 Thanks Meter: 60 | Lenevo a1000 unlock err lanevo a1000 unlock err Card found: S/N : 9C0C15D6 , v0136 Chinese Miracle II [SPD module] v 1.26 Set mode to : SP SC77xx [Model Select] SLDR Load Ok BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : SP Unlock [ v1.26 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 183 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : SP Unlock [ v1.26 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 183 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
The Following User Says Thank You to dubai@mobile For This Useful Post: |
05-14-2017, 15:06 | #135 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | I received semi dead condition. I found a similar firmware which is not fully compatible. every thing is fine except keypad config. in other words for R&D I can say yes I have a phone with factory pac. Currently phone unlocked cuz I wrote unlocked firmware. |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
