Old 05-29-2019, 10:29   #31 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
@Elasunuas
you can use FDL1 and FDL2 as custom from pac file
or you can select direct pac file (even short and full) do identify sw will make and add auto in database for future use just need to restart exe for accept changes
here i attached ITEL P33+ loader just paste it into (C:\InfinityBox\CM2SP2\Boot\Itel) select ITEL W6001 and do service, post result if any error
https://mega.nz/#!IOZwQCbI!oNbh9KfY4...m41NugSuHS6T7o
The Following 2 Users Say Thank You to kamal_singla For This Useful Post:
Old 05-29-2019, 10:49   #32 (permalink)
Member: 2263412
Thanks Meter: 86
I love infinity and all service of the team.
This new service have one ploblem.
Sp unlock is disabled
plz sir fix or enable this
thanks
The Following User Says Thank You to pink009 For This Useful Post:
Old 05-29-2019, 11:00   #33 (permalink)
sajidi1984's Avatar
Member: 2778467
Sonork: only Telegram
Thanks Meter: 265
this is the real world first update thanks infinity team
The Following 2 Users Say Thank You to sajidi1984 For This Useful Post:
Old 05-29-2019, 11:48   #34 (permalink)
Member: 1208596
Thanks Meter: 23
nice work infinity team!
two thumbs up
Old 05-29-2019, 12:07   #35 (permalink)
Member: 2208114
Thanks Meter: 5
The Reset Privacy and Reset User Locks (Data Safe) are not enabled on my CM2 SP2 and MT2 please any solution to that
Old 05-29-2019, 12:12   #36 (permalink)
Member: 964645
Sonork: Moha
Thanks Meter: 2
Infinity Team always on the time ����
Old 05-29-2019, 12:21   #37 (permalink)
Member: 1677653
Thanks Meter: 2,769
WELDONE TO JAYDI SIR & INFINITY-BOX TEAM,
Dear JayDi Sir,
Does it possible to add model & boot selected to log and bottom of screenshot? If possible please add.
To make it easy for you and some lazy users, can you add CREATE LOADER button? So that we can able to extract loader from factory firmware.
Some latest SPD device only connect in DIAG MODE, do you have plan for this?
Thanks in advance...
Br.
Yuslam Unique Ventures,
Nigeria.
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 05-29-2019, 12:23   #38 (permalink)
Member: 1677653
Thanks Meter: 2,769
It will be enable in upcoming update, please stay tune....
Old 05-29-2019, 12:38   #39 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Do you have SPD device with enabled privacy lock?
Old 05-29-2019, 12:44   #40 (permalink)
Member: 1677653
Thanks Meter: 2,769
Originally Posted by JayDi View Post
Yes, will add
Not need. Just select FW in flash tab, for example. Rest will be done by SW itself. At next start you find it in models list.
Post examples of such devices, please.
Not with sample ATM, once i have such will notify you Sir.
Thanks for your understanding..
Old 05-29-2019, 13:00   #41 (permalink)
Shah87n's Avatar
Member: 234396
Thanks Meter: 9
= DongleManager [Infinity] v1.70 [29-May-19 13:25:59] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0000D00000000
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): xxxxxxxxx
Firmware version: 0136.02
=== Process started: 29-May-19 13:26:01 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
whats issu
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Old 05-29-2019, 13:33   #42 (permalink)
Member: 2824001
Thanks Meter: 110
Infinty Team. consider SPD8810/6820 Chip also. Otherwise new module is superb.!
Old 05-29-2019, 13:37   #43 (permalink)
jrbravo's Avatar
Member: 2545468
Thanks Meter: 234
showing that the seniority is a high grade thanks for the update team infinity !!!
Old 05-29-2019, 14:25   #44 (permalink)
JayDi's Avatar
Member: 462970
It supported in SCR module. Check it for more info.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 05-29-2019, 14:52   #45 (permalink)
Member: 1677653
Thanks Meter: 2,769
HWID: 0000D00000000
Reading...
whats issu
Don't retry again to avoid dongle blocked.
It's time to renew your support
Page generated in 0.23729 seconds with 8 queries
