05-01-2020, 14:05 | #46 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
05-01-2020, 15:18 | #51 (permalink) | |
It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ | |
05-01-2020, 20:44 | #53 (permalink) |
Insane Poster Join Date: Feb 2020 Location: ................
Member: 2948043 Status: Offline Thanks Meter: 3 | Yes, I found it fault : 35 octets ( E R R O R : P R I V I L E G E )... i delete it and turn off kaspersky , then reinstall cm2spd2 2.05 again... the same problem.. |
05-02-2020, 08:38 | #57 (permalink) |
No Life Poster Join Date: Jul 2007 Location: https://www.facebook.com/group
Member: 556396 Status: Offline Sonork: 100.1609417 Thanks Meter: 363 | Card found : A9F77866 , v0143 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
05-02-2020, 09:20 | #58 (permalink) | |
Member: 556396 Status: Offline Sonork: 100.1609417 Thanks Meter: 363 | Quote:
Card found : A9F77866 , v0143 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS_LOW Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_SS Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7715_BASE : SC7715_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.05 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7715_BASE : SC7715_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7715x_BASE : SC7715G_NAND_256MB_NS Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.05 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7715_BASE : SC7715_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! | |
05-02-2020, 11:38 | #60 (permalink) |
Insane Poster Join Date: Mar 2020 Location: Jauharabad, Punjab , Pakistan
Member: 2951507 Status: Offline Thanks Meter: 11 | HELLO INFINITY TEAM GREETING! I WOULD LIKE TO SHARE A PAINFUL BUG OF INFINITY UPDATE NOW A DAYS PLEASE CHECK BELOW MY ALL ERROR DETAIL ! BEFORE IT WAS HAPPEN ON LATEST UPDATE CM2 SCR 1.06 MODULE UNTIL NOW THERE IS NO SOLUTION ! AND NOW THIS ERROR IM GETTING ON SAME cm2spd2 2.05 UPDATE. THERE IS NO SIGN OF ANY VIRUS ALREADY INSTALLED FRESH WINDOW 10 ENTERPRISE 64 BIT 1ST OF ALL CHECK DONGLE FIRMWARE DETAIL: Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): XXXXXXX Firmware version: 0143.02 => Activations: - 00: Infinity-Box/Dongle v0143 NOW WHEN I INSTALLED CM2 SP2 (2.05) VERSION AND I GET THESE ERROR ERROR NO# 1 https://imgur.com/Fs6dmZs after press Ok The Open Module like this error # 2 https://imgur.com/GvKzRJE every thing empty in this module! before i was getting same issue on cm2 scr 1.06 module but for mine 1.05 module working Ok and Also Previous version of cm2sp2 2.04 working Fine Only The new updates Are very Very such a Painful becoz if i got these error so its mean i cannot use new modules ! Addational Deatil: System Info : https://imgur.com/rbn59CA |
