01-19-2021, 17:00 | #347 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Data Explorer v1.11 - MTK, SPD updated and more improvements Data extraction based on full reconstruction of file system - MTK module updated - added Call List extraction for some models - SPD firmware structure detection improved, important algos and methods updated - Minor bugs fixed |
01-20-2021, 14:29 | #348 (permalink) | |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | Quote:
01-20-2021, 20:06 | #352 (permalink) | |
nokia 230 ? i know that noka 208 can do that ! but it is with the old best it is in the forensic funtion do you have similar funtion in the new one? | |
01-20-2021, 22:28 | #353 (permalink) | |
If you want to check software functions before buy you can upload your firmware somewhere and support team will test your firmware with Infinity Data Explorer. | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
01-21-2021, 15:04 | #354 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Philips-580 tested with Infinity Data Explorer and found supported Operation : Extract Data from MTK Dump [v1.09] Loading file : Philips-E580_B142_S04A_PCB01_gprs_MT6260_S00.E580_M6260A_1 922_V15A_RU.bin ... OK Detected SF_BOOT Type *** Memory Info : [0200][0001][0000] Searching FileSystem ... OK *** FileSystem found at: [00C00000] size: [003FE000] Extracting FileSystem ... *** Stage #1 *** Stage #2 Checking FileSystem image ... OK Searching additional data ... *** IMEI[0]: .... *** IMEI[1]: .... *** Sec Code : 1122 [NOT ACTIVE] Searching required data ... *** Names Found *** Numbers Found *** Messages Found Extracting contacts... *** PhoneBook size: 1000 contact(s) *** Extracted 802 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\Philips-E580_B142_S04A_PCB01_gprs_MT6260_S00.E580_M6260A_1 922_V15A_RU_21_01_2021_15_01\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\Philips-E580_B142_S04A_PCB01_gprs_MT6260_S00.E580_M6260A_1 922_V15A_RU_21_01_2021_15_01\ HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\Philips-E580_B142_S04A_PCB01_gprs_MT6260_S00.E580_M6260A_1 922_V15A_RU_21_01_2021_15_01\ Extracting messages... *** Extracted 78 message(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\Philips-E580_B142_S04A_PCB01_gprs_MT6260_S00.E580_M6260A_1 922_V15A_RU_21_01_2021_15_01\ Finish. |
01-21-2021, 15:06 | #355 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | BQ-2432 tested with Infinity Data Explorer and found supported Operation : Extract Data from MTK Dump [v1.09] Loading file : BQ-2432_T262B_X8_TWWD_PCB01_gprs_MT6261_S00.T262B_BQ_ X8_TWWD_V18_20200615.bin ... OK Detected SF_BOOT Type *** Memory Info : [0200][0001][0000] Searching FileSystem ... OK *** FileSystem found at: [003AC000] size: [00052000] Extracting FileSystem ... *** Stage #1 *** Stage #2 Checking FileSystem image ... OK Searching additional data ... *** IMEI[0]: ... *** IMEI[1]: ... *** Sec Code : 1234 [NOT ACTIVE] Searching required data ... *** Names Found *** Numbers Found *** Messages Found Extracting contacts... *** PhoneBook size: 500 contact(s) *** Extracted 251 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\BQ-2432_T262B_X8_TWWD_PCB01_gprs_MT6261_S00.T262B_BQ_ X8_TWWD_V18_20200615_21_01_2021_15_05\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\BQ-2432_T262B_X8_TWWD_PCB01_gprs_MT6261_S00.T262B_BQ_ X8_TWWD_V18_20200615_21_01_2021_15_05\ HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\BQ-2432_T262B_X8_TWWD_PCB01_gprs_MT6261_S00.T262B_BQ_ X8_TWWD_V18_20200615_21_01_2021_15_05\ Extracting messages... *** Extracted 5 message(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\BQ-2432_T262B_X8_TWWD_PCB01_gprs_MT6261_S00.T262B_BQ_ X8_TWWD_V18_20200615_21_01_2021_15_05\ Finish. |
01-21-2021, 15:11 | #356 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | LandRover-F8 tested with Infinity Data Explorer Operation : Extract Data SPD [v1.09] Source: Dump SPD653x Loading file : LandRover-F8_SC6531_Z116P_GG_YSF_F8_Y809_EN_V1.4_T161115.653 1A_GD27LQ64.bin ... OK Searching FileSystem ... OK *** FileSystem found at: [00798000] size: [00068000] *** Memory Info : [00008000][0000000D] Extracting FileSystem ... *** Stage #1 Searching additional data ... *** IMEI[0]: ... *** IMEI[1]: ... *** Sec Code : 1234 [NOT ACTIVE] Searching required data ... *** Contacts Found *** Messages Found Extracting contacts... *** Extracted 480 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\LandRover-F8_SC6531_Z116P_GG_YSF_F8_Y809_EN_V1.4_T161115.653 1A_GD27LQ64_21_01_2021_15_09\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\LandRover-F8_SC6531_Z116P_GG_YSF_F8_Y809_EN_V1.4_T161115.653 1A_GD27LQ64_21_01_2021_15_09\ HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\LandRover-F8_SC6531_Z116P_GG_YSF_F8_Y809_EN_V1.4_T161115.653 1A_GD27LQ64_21_01_2021_15_09\ Extracting messages... *** Extracted 122 message(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\LandRover-F8_SC6531_Z116P_GG_YSF_F8_Y809_EN_V1.4_T161115.653 1A_GD27LQ64_21_01_2021_15_09\ Finish. |
01-21-2021, 16:11 | #357 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Vertex-D514 supported by Infinity Data Explorer Operation : Extract Data SPD [v1.09] Source: Dump SPD653x Loading file : Vertex-D514_SPRD_SPI_WINBOND_W25Q.SC6531EFM_W17.42.1І_4Mi B.bin ... OK Searching FileSystem ... OK *** FileSystem found at: [003E0000] size: [00020000] *** Memory Info : [00008000][00000004] Extracting FileSystem ... *** Stage #1 Searching additional data ... *** Sec Code : 1234 [NOT ACTIVE] Searching required data ... *** Contacts Found *** Messages Found Extracting contacts... *** Extracted 86 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\Vertex-D514_SPRD_SPI_WINBOND_W25Q.SC6531EFM_W17.42.1І_4Mi B_21_01_2021_16_02\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\Vertex-D514_SPRD_SPI_WINBOND_W25Q.SC6531EFM_W17.42.1І_4Mi B_21_01_2021_16_02\ HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\Vertex-D514_SPRD_SPI_WINBOND_W25Q.SC6531EFM_W17.42.1І_4Mi B_21_01_2021_16_02\ Extracting messages... *** Extracted 53 message(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\Vertex-D514_SPRD_SPI_WINBOND_W25Q.SC6531EFM_W17.42.1І_4Mi B_21_01_2021_16_02\ Finish. Last edited by YellowBoss; 01-21-2021 at 17:29. |
