Old 06-15-2021, 13:54   #1 (permalink)
Member: 2803071
Thanks Meter: 46
itel w6501 flashing failed...i've tried using different files
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : PAC : W6501-F3111-9.0-OP-V032-20210301_1342_user.pac
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False
FDL : RAW : 0x0001
FDL : FLH : 0x400000
FDL : SEC : RSA auth required!
>>> ERROR : FLASH FDL AUTHENTIFICATION FAILED!
>>> Error : Fail to boot FDL!
>>> Check previous message for more info!
Reconnect Power/Cable!
Old 06-15-2021, 14:06   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
What is the CM2SP2 version?
What was the problem with the phone when you got it for repair?
Old 06-15-2021, 14:34   #3 (permalink)
Member: 2809120
Thanks Meter: 83
Originally Posted by elmowaldo View Post
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : RAW : 0x0001
Hi
As per Jady this phone flash need RSA Authentification from server and this is available using test version 2.23, just seach it , u need to connect to internet and put your user and psw then u will flash this phone .
regards
leroi
Old 06-15-2021, 14:39   #4 (permalink)
Member: 2809120
Thanks Meter: 83
please check here for more information
https://forum.gsmhosting.com/vbb/f29...04/index3.html
The Following User Says Thank You to leroi2018 For This Useful Post:
Old 06-15-2021, 16:56   #5 (permalink)
Member: 2812901
Thanks Meter: 493
Originally Posted by leroi2018 View Post
Hi
regards
leroi
As per log in this test version v2.13
I don't think server needed just download and test it
https://cdn.infinity-box.com/tmp/SP2v213-ykajsaenfk.7z
The Following User Says Thank You to Oyetunde Semiu For This Useful Post:
Old 06-15-2021, 17:00   #6 (permalink)
Member: 2809120
Thanks Meter: 83
1
still returning server error(FDL : SEC : RSA auth required!
FDL : Process authentification ...
Server Error :
>>> ERROR : Server process failed!
2
FDL : SEC : RSA auth passed!
FDL : Control transfered!
Old 06-16-2021, 11:57   #7 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
1
Server Error :
2
Update with test support of itel devices with RSA auth can be found here :
https://forum.gsmhosting.com/vbb/14409459-post40.html
Need put in EXISITNG SP2 folder and fill login/password to use!
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 06-16-2021, 16:20   #8 (permalink)
Member: 2812901
Thanks Meter: 493
Card found : 5B5B5xxx , v0149
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13
Load IDBase v8331 Ok!
Operation : Identify [ v2.13 ]
BootMode : SVC
1. Power off device, wait 10-15 seconds
2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
SOC GEN : UniSoc ( E-family and Modern )
BuildInfo : W6501-F3111-9.0-OP2-V009-20200605
MemoryInfo : EMMC : 32 GB ; DRAM : 2 GB
Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug
Project Version: pike2_pub
BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P5
HW Version: sc7731e_modem
CMP_Time : 12-25-2019 16:59:14
MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P5_sc7731e_modem_pike2_pub
PSN1 : 056963707I005668
NVMng : SecurityInfo
IMEI[1] : 356660500409xxx
IMEI[2] : 356660500409xxx
WIFIMAC : 40D25FF756D9
BT_MAC : 40D25FF756D8
SEC : SLS:0, SKS:0, SKV:4
Done!
Elapsed: 00:00:35
BootMode : FLASH
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS
Boot sent!
Kick FDL ...
>>> ERROR : FDL NOT started!
>>> Unsupported device with selected fdl or settings! Change settings!
Old 06-16-2021, 16:21   #9 (permalink)
Member: 2812901
Thanks Meter: 493
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
Done!
Elapsed: 00:00:35
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Old 06-16-2021, 17:14   #10 (permalink)
Member: 1677653
Thanks Meter: 2,769
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
Done!
Elapsed: 00:00:35
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
https://forum.gsmhosting.com/vbb/14410018-post41.html
Old 06-16-2021, 17:57   #11 (permalink)
Member: 2812901
Thanks Meter: 493
Originally Posted by Yusuf Lawal View Post
My version is different from yours, mine is _32+2.
Urs is 16+1
Old 06-16-2021, 19:01   #12 (permalink)
Member: 1677653
Thanks Meter: 2,769
Urs is 16+1
Loader should work for all. But if not work check other thread for alternative.
Old 02-20-2023, 13:24   #13 (permalink)
bijoychowdry's Avatar
Member: 1984655
Sonork: 119.30.39.25
Thanks Meter: 81
Product Brand : Itel
Product Device : L6502
Product Model : itel L6502
Product Name : L6502
Patch Level : QP1A.190711.020
Display ID : L6502-F3208-10.0-IN-V020-20201012
Ver. Incmt : IN-V020-20201012
Ver. CodeName : REL
Ver. Release : 10
Sec. Patch : 2020-09-01
Build Time : 12.10.2020
Product Name : F3208
Product Device : itel-L6502
Product Info : L6502
Product Board : L6502
Board Platform : sp9832e
Product Manfct : itel
Operation : Flash Firmware [ v2.14 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : Update PMT : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : PAC : L6502-F3208-10.0-IN-V020-20201012_1434_user.pac
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : RAW : 0x0002
>>> Error : UserDetails ( Login or/and PWD ) wrong or empty!
>>> Enter User Details in Settings tab first!
Old 02-21-2023, 02:52   #14 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,054
Input Correct User & Password.
https://infinity-box.com/service/
Br,
xerraco
The Following User Says Thank You to xerraco For This Useful Post:
Old 02-22-2023, 11:21   #15 (permalink)
Member: 1043909
Ver. CodeName : REL
Ver. Release : 10
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : RAW : 0x0002
Your Username and Password are here https://infinity-box.com/service/
Enter it this way https://infinity-box.com/?r=100166
Page generated in 0.35951 seconds with 8 queries
