06-15-2021, 13:54 | #1 (permalink) |
Freak Poster Join Date: Jan 2018 Location: Ghana
Member: 2803071 Status: Offline Thanks Meter: 46 | itel w6501 flashing failed...i've tried using different files Device Connected! BootVersion : SPRD3 Boot : PAC : W6501-F3111-9.0-OP-V032-20210301_1342_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
06-15-2021, 14:34 | #3 (permalink) | |
Freak Poster Join Date: Feb 2018 Location: Congo Brazzaville
Member: 2809120 Status: Offline Thanks Meter: 83 | Quote:
Hi As per Jady this phone flash need RSA Authentification from server and this is available using test version 2.23, just seach it , u need to connect to internet and put your user and psw then u will flash this phone . regards leroi | |
06-15-2021, 16:56 | #5 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Quote:
As per log in this test version v2.13 I don't think server needed just download and test it https://cdn.infinity-box.com/tmp/SP2v213-ykajsaenfk.7z | |
The Following User Says Thank You to Oyetunde Semiu For This Useful Post: |
06-15-2021, 17:00 | #6 (permalink) | |
still returning server error(FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! 2 DL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! | |
The Following User Says Thank You to leroi2018 For This Useful Post: |
06-16-2021, 11:57 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
https://forum.gsmhosting.com/vbb/14409459-post40.html Need put in EXISITNG SP2 folder and fill login/password to use! | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
06-16-2021, 16:20 | #8 (permalink) |
Member: 2812901 Status: Offline Thanks Meter: 493 | Card found : 5B5B5xxx , v0149 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Identify [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : W6501-F3111-9.0-OP2-V009-20200605 MemoryInfo : EMMC : 32 GB ; DRAM : 2 GB Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P5 HW Version: sc7731e_modem CMP_Time : 12-25-2019 16:59:14 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P5_sc7731e_modem_pike2_pub PSN1 : 056963707I005668 NVMng : SecurityInfo IMEI[1] : 356660500409xxx IMEI[2] : 356660500409xxx WIFIMAC : 40D25FF756D9 BT_MAC : 40D25FF756D8 SEC : SLS:0, SKS:0, SKV:4 Done! Elapsed: 00:00:35 Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
06-16-2021, 16:21 | #9 (permalink) | |
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Identify [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : W6501-F3111-9.0-OP2-V009-20200605 MemoryInfo : EMMC : 32 GB ; DRAM : 2 GB Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P5 HW Version: sc7731e_modem CMP_Time : 12-25-2019 16:59:14 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P5_sc7731e_modem_pike2_pub PSN1 : 056963707I005668 NVMng : SecurityInfo IMEI[1] : 356660500409xxx IMEI[2] : 356660500409xxx WIFIMAC : 40D25FF756D9 BT_MAC : 40D25FF756D8 SEC : SLS:0, SKS:0, SKV:4 Done! Elapsed: 00:00:35 Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! | |
06-16-2021, 17:14 | #10 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
02-20-2023, 13:24 | #13 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Product Brand : Itel Product Device : L6502 Product Model : itel L6502 Product Name : L6502 Patch Level : QP1A.190711.020 Display ID : L6502-F3208-10.0-IN-V020-20201012 Ver. Incmt : IN-V020-20201012 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-09-01 Build Time : 12.10.2020 Product Name : F3208 Product Device : itel-L6502 Product Info : L6502 Product Board : L6502 Board Platform : sp9832e Product Manfct : itel Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L6502-F3208-10.0-IN-V020-20201012_1434_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... >>> Error : UserDetails ( Login or/and PWD ) wrong or empty! >>> Enter User Details in Settings tab first! Reconnect Power/Cable! >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
02-22-2023, 11:21 | #15 (permalink) | |
Enter it this way https://infinity-box.com/?r=100166 | |
