12-17-2008, 10:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Pakistan Age: 33
Member: 323959 Status: Offline Sonork: 100.1613721 Thanks Meter: 79 | kg290 flashing error module v1.36 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KG290_20061217-012508.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 89881600010001:89881600000000 error: wrong answer: B1 error: flash write error: 01020000:00020000 Write Fail Finished, time used: 108 sec Remove/Install battery now ! infinity tam plz help |
LG - KG290 flashing error | Dilip_Nath | Infinity-Box | 33 | 03-11-2011 18:57 |
LG KG290 Flashing Error | ARS.Rehman | Infinity-Box | 9 | 04-08-2009 13:34 |
KG290 flash error | murtaza_nns | Infinity-Box | 7 | 03-23-2009 07:23 |
kg290 flash error with infinity | zeeshan tayyab | Infinity-Box | 1 | 02-18-2009 19:54 |
Kg290 flashing error | oMeR_Rasheed | Infinity-Box | 3 | 01-10-2009 14:19 |
