08-19-2008, 13:59 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: PakLink.org
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | J110i can't unlock Device: Sony-Ericsson-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 100C-000 version sw: KIM-5- Check hardware done Read data... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20080818-191657.6AE.bin Read data done Check data... error: not locked or unknown eeprom Check data done Writing... .error: required data not found or unknown eeprom structure Writing fail Finished, time used: 16 sec Remove/Install battery now ! |
08-21-2008, 15:51 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It is not possible that phone become dead after this operation. You must charge phone battery, flash phone agaian and then, if you will see "not authorized" text at phone LCD, press "Repair" button in software to fix yor phone in seconds. |
09-02-2008, 08:07 | #5 (permalink) | |
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | Quote:
COM1 [Serial0] selected Device: Sony-Ericsson-J110i "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... error: can't load bootcode Boot fail Finished, time used: 68 sec Remove/Install battery now ! | |
09-02-2008, 08:18 | #6 (permalink) | |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | Quote:
cheak ur baudrate select speed to 115200 | |
09-02-2008, 12:25 | #9 (permalink) |
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | cable is ok phone can tetect by other tool use same cable cable have only 3 wire Rx Tx GND , i use same cable already for write eprom after write eprom mobile going dead even batry fully charged then same batry & cable use for other tool that not able to unlock this mobiel but can alive dead mobile so that is sure cable r ok & working |
09-02-2008, 12:47 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I can not understand now... Please, explain me so detailed as possible what is your next wortds means: 1. "mobile dead" from your post: http:///vbb/showpo...74&postcount=3 2. "Phone Alive" from your post: http:///vbb/showpo...14&postcount=5 |
09-02-2008, 13:17 | #11 (permalink) |
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | eeprom files from support then i write it then press unlock but after that mobile no power on i try with other batry too then i use other software ( s E Tool ) then repair mobile then mobile alive but S E Tool never can unlock this so i try again with infinity then i got this problem |
09-02-2008, 13:49 | #13 (permalink) | |
Try to disconnect cable, then press "unlock" button and then connect cable to phone. | |
Sony Ericson J110i can't unlock | Unicom | Infinity-Box | 5 | 04-21-2011 07:56 |
J110i can't unlock with Smart clip | Unicom | Smart-Clip | 2 | 01-31-2009 12:47 |
J110i can't unlock | paklink | Smart-Clip | 5 | 08-20-2008 08:00 |
Please j110i can't unlock..... | karikari | Infinity-Box | 1 | 10-22-2007 17:06 |
J110i still can't unlock | bonghernz | Infinity-Box | 6 | 10-06-2007 11:18 |
