03-27-2008, 16:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Where the cash @... Age: 38
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | J110i Unauthorized phone COM3 [VCP0] selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... Set baud done Check hardware... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check hardware done Read data... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson J110i_eeprom_calibration-1_20080327-185531.6AE.bin Read data done Check data... error: not locked or unknown eeprom Check data done Writing... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Writing done Finished, time used: 114 sec Remove/Install battery now ! I tried to unlock this phone several time without success. |
03-27-2008, 17:45 | #3 (permalink) | |
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | Quote:
Device: Sony-Ericsson J110i "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... Set baud done Check hardware... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check hardware done Read data... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson J110i_eeprom_calibration-1_20080327-194244.6AE.bin Read data done Check data... Check data done Writing... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Writing done Finished, time used: 30 sec Remove/Install battery now ! Same thing after repair. I checked the IMEI is blank. Any Idea? | |
03-28-2008, 08:13 | #6 (permalink) | |
I didnt ignore your advice Sir. Here is the log I got after flash. COM3 [VCP0] selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... Set baud done Check hardware... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check hardware done Read data... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson J110i_eeprom_calibration-1_20080328-101510.6AE.bin Read data done Check data... Check data done Writing... Area: Firmware flash: 89886200010001:89886200000000 Write: Firmware Area: Flex flash: 89886200010001:89886200000000 Write: Flex error: wrong answer[3B] error: flash write error: 003B0000:00002000 error: wrong answer[3B] error: flash write error: 003B0000:00002000 error: wrong answer[3B] error: flash write error: 003B0000:00002000 003E38000000C3020000000000000000000000000000000000 Writing fail Finished, time used: 38 sec Remove/Install battery now ! | |
03-28-2008, 10:34 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. use latest software from support area 2. try to write eeprom again if eeprom can't be written I think this means that phone has hardware problem and probably you need to reball flash chip. |
10-24-2008, 21:51 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Write repair eeprom. Make repair operation (repair button). |
01-26-2009, 00:20 | #11 (permalink) |
Freak Poster Join Date: Apr 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 484166 Status: Offline Thanks Meter: 11 | bro just use this Method ... flash ur phone with both files .. eeprom + ffs but the same name and ur phone will back again J110i_repair_eeprom_0B.6AE J110i_repair_ffs_0B.6AF thank u all |
The Following User Says Thank You to Tracer Gsm For This Useful Post: |
01-26-2009, 00:21 | #12 (permalink) |
Member: 484166 Status: Offline Thanks Meter: 11 | And Make Repair Hello, Write repair eeprom. Make repair operation (repair button). ty infinity Support best job |
J110i Unauthorized phone???? | cllins | Infinity-Box | 7 | 04-21-2011 07:56 |
Unauthorize phone S/E J110i | cllins | Infinity-Box | 2 | 05-07-2010 10:51 |
J110i unauthorized phone....REPAIRED | rea1One | Infinity-Box | 1 | 06-20-2008 17:29 |
SONY ERICSSON J110i UNAUTHORIZED Problem | JKKB | Infinity-Box | 7 | 03-26-2008 13:31 |
moto c168 shows UNAUTHORIZE PHONE | sonuk | Motorola Hardware Repair | 1 | 06-02-2006 06:46 |
