09-14-2008, 07:13 | #17 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | Quote:
very successful...tru remove N1 ball in order to detect the phone in inifinity box. 1. remove N1 ball 2. connect to infinty and flash it 3.then do hardware usual modification it works 100% br, | |
09-26-2008, 02:06 | #18 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | tested 1000% 1. Open phone and cut track according to test-point picture in “Documentation” folder 2. Now phone can’t power-on but can be connected to software and unlocked/flashed in “Repair mode” 3. If phone still can power-on with cutted track this means that: 3.1. Track cutted not correctly, double check that track cutted well and continue with instruction below: 3.2. New phone PCB type, need to desolder CPU, remove ball “N1” and continue with instruction below: 4. Run “Moto02” module (ver 1.25 or higher) 5. Go to “Settings” page and make “Repair mode” connection box checked 6. If you don't want to restore cutted track back after repair procedure make "Soft restore" cutted track option checked 7. Optional step: make flash backup (read flash) for emergency case 8. Flash phone with the next flash files from support area (letter x means any): 1.x.xx 2.0.xx 2.1.xx 9. Optional step: make "sp-unlock" operation 10. Restore track back (if "Soft restore" cutted track option was not checked during flash operation) |
10-02-2008, 16:08 | #20 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | Quote:
10-03-2008, 18:00 | #21 (permalink) |
No Life Poster Join Date: Dec 2003 Location: in the center of the heart
Member: 46125 Status: Offline Thanks Meter: 59 | please dont repeat this CUT TRACK SOLUTION....Please post some newest solution if some one has it AS I ALREADY SAID ...THIS SOLUTION IS VERY DIFFICULT IF U HAVE A BIG QUANTITY TO CONVERT |
New Version 9.2.17 C139 Trafone Firmware Dump!!! UNLOCKED! | dump101 | Motorola ODM | 51 | 02-21-2010 09:46 |
New Version 9.2.17 Unlocked! C139 | gsm1999 | Motorola ODM | 8 | 03-18-2008 19:41 |
