07-20-2008, 08:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | need flash file voda 125 &' 225 plz infinity support help |
The Following User Says Thank You to hanif007 For This Useful Post: |
07-20-2008, 09:06 | #2 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
check in zte section you will found what you want. | |
The Following 2 Users Say Thank You to zinoubinabil For This Useful Post: |
07-29-2008, 22:57 | #6 (permalink) |
No Life Poster Join Date: Nov 2005 Location: romania
Member: 201764 Status: Offline Thanks Meter: 76 | same problem , Hi, I have a same problem ,but when i flash my new phones vodafone 125 ,to change language packages(into romanian flashfiles),phones bateries are weak(i mean phones dont wanna stay on more then 4 hours).What can i do to my phones to stay charged more then 4 hour? |
07-30-2008, 13:02 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | I don\'t think that firmware upgrade can give such results. Anyway, if you think that its a result of firmware upgrade you can try to flash phone with other firmware and see results. |
07-31-2008, 20:56 | #9 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | dear, if your phone not ask to enter unlock code; that's mean your phone is blocked. & infinity box not support phone blocked yet! |
08-01-2008, 08:04 | #10 (permalink) |
Freak Poster Join Date: Dec 2004 Location: UNITED KINGDOM
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | i have problam infinity unlocked ok but phone is still locked then i try to unlock again but software says phone is already unlocked what can i do Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20080801-115152.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20080801-115156.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20080801-115203.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 35 sec |
10-13-2008, 12:33 | #14 (permalink) |
Freak Poster Join Date: Sep 2005 Location: R474 5VS
Member: 176999 Status: Offline Thanks Meter: 32 | My phone Vodafone ZTE 125 dead flashing use infinity this log : COM7 [VCP0] selected Device: ZTE-125 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20081013-182058.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20081013-182529.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20081013-183036.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 681 sec |
NKTEL A200 flash file in Spider man box need flash file? | >>.123.<< | SpiderMan | 15 | 11-12-2010 16:12 |
I need flash for vodafone 125 | Nestor7 | FuriousGold | 2 | 10-31-2008 10:24 |
want ARABIC flash file for 6030b rm-225 | Muneer Ahmed | Wanted Products | 0 | 06-26-2007 15:06 |
@@v 600i voda phone need flash files@@ | rajabrotherscom | Cruiser Suite | 4 | 03-27-2007 00:30 |
Need Flash file RM-225 | Bao Tran | Nokia Hardware & Hardware Repair | 9 | 12-24-2006 11:30 |
