05-26-2008, 12:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | Touchscreen Bypass damaged calibration solution 100% work for me!!! @InfinitySupport !!! for wonder full update ""Bypass damaged Touchscreen calibration"". i have 2 pic N-73 sucessfully repair bye new version 2.45. ((problem- touchscreen not work so mobile is stop on Touchscreen calibration. Today mobile is alive )). COM19 [VCP3] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6219:8B02:8B01]... CPU: MT6219 high speed boot enabled chip: 0031:3A41:3C08 CPU: MT6226MA detected Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: ZX860_THL_1.1 Version: ZX26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35972500000408 connection Ok detecting structure #5... 0done 204 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to kalpeshoza For This Useful Post: |
01-28-2009, 11:25 | #2 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | working ok in sigmatelS3 COM46 [VCP0] selected module v2.73 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A903:0007 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1.0.013_080306 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 11 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to kalpeshoza For This Useful Post: |
01-31-2009, 13:24 | #3 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | working on "MT 1588 2SIM" JUST use method 2 working fine COM46 [VCP0] selected module v2.73 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9603:0007 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: 931028_79I_V0003 Version: TIANYU25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35848801000090 connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! |
02-20-2009, 06:56 | #4 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | working ok in ZTC 168 SINGLE SIM COM46 [VCP0] selected module v2.73 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8603:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.06B.W07.24.MP.V16.F1 Version: MP_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 9 sec Remove/Install battery now ! |
04-09-2009, 11:35 | #5 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | Again working on gsm jg268 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9B03:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI_06B_ZM24H_V1.3 Version: MT25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 25 sec Remove/Install battery now ! |
04-15-2009, 11:45 | #6 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | Saha model as810 Today calibration repair on saha as810 first i have try with calibration touchscreen but give eror RANGE CHECK ERROR. then first format COM4 [VCP1] selected module v2.80 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6CC1:15AA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M968CSL_6226b_11H Version: M968c_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 136 warning: wrong packet cs items cleared: 136 of 136 building list... done items remains: 0 Finished, time used: 159 sec Remove/Install battery now ! and then calibration touchscreen working file after format COM4 [VCP1] selected module v2.80 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6CC1:15AA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M968CSL_6226b_11H Version: M968c_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 20 sec Remove/Install battery now ! br kalpeshoza |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
04-21-2009, 14:15 | #7 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | Again working on sigmatel v88 COM4 [VCP1] selected module v2.80 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8E03:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.06B.W07.24 Version: 6225_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... warning: wrong packet cs done 162 byte(s) read reading data #2... writing data... verification... verification Ok Finished, time used: 15 sec Remove/Install battery now ! |
07-21-2009, 08:42 | #8 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | GSM 2SIM 810i COM21 [VCP1] selected module v2.84 Action: touchscreen calibration mode: 1 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E403:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: V6S_V3.6.4_0411_SM Version: HW_2.0 detecting structure #2... 0 6 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 19 18 17 16 done 160 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" UN-checked and try again 2. try another calibration mode Finished, time used: 20 sec Remove/Install battery now ! |
07-29-2009, 22:39 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | How to calibrate touchscreen (if toucscreen panel is damaged): 1. connect cable from box to phone 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model 6. go to software "Settings" page and select COM port 7. make full flash backup for emergency case 8. go to software "Service" page 9. select calibration "mode-1" 10. make "Reverse calibration order" un-checked 11. press "Calibrate touchscrren" button and follow instruction given by software 12. if software can not make calibration with "detection failed" error: - select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one) - repeat calibration process - test phone after each "mode" try 13. if calibration process finished without errors but touchscreen can not work well: - DO NOT change calibration "mode" ! - make "Reverse calibration order" option checked - repeat calibration process again - test phone 14. if still no luck with calibration after all tries: - make full flash backup for emergency case - make "format ffs" - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
08-27-2009, 07:19 | #10 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | Rocky 2008 working fine COM45 [VCP1] selected module v2.90 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.POPHONE_KY_VER SION_1_8__fullflash_20090827-104834.B0M.bin loaded detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3803:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: POPHONE_KY_version_1_8 Version: POPHONE_6225_06B_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 160 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 17 sec Remove/Install battery now ! |
08-31-2009, 15:33 | #11 (permalink) |
Registered User Join Date: Nov 2007 Location: ID
Member: 624177 Status: Offline Thanks Meter: 23 | i have problem with THL ( HTC Diamond chinese model) A1000_E802_JJFF5D_EVCOM_MT6225S00.01_0_20090112__f ullflash_20090825-175357.B0M.bin after format fss: complete mode and then doing pen callibration mode-1 Code: COM4 selected module v2.91 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... THL_A1000_E802_JJFF5D_EVCOM_MT6225S00.01_0_20090112__fullflash_20090825-175357.B0M.bin loaded detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:F003:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E890_EVSMT3B.01.1 Version: EVEN6225_GEMINI_HW 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 213 byte(s) read reading data #2... reading data #3... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! help..... |
The Following User Says Thank You to teknisi bloon For This Useful Post: |
09-11-2009, 18:17 | #13 (permalink) |
Insane Poster Join Date: Aug 2006 Location: india
Member: 325604 Status: Offline Thanks Meter: 14 | i have suceeded by passing calibration for every mobile...thnaks to infinity for their great efforts.. |
The Following User Says Thank You to SATISH BABU For This Useful Post: |
Nokia 1680 camera solution...100% working.tested by me. | mahbubalfa | Nokia Hardware & Hardware Repair | 64 | 08-04-2012 19:59 |
B3310 Solution that worked for me | kobolt | UST Pro II | 0 | 12-18-2009 17:39 |
solution 100% working for HWK 2.5 shut down pc | hicvb7 | HWK | 13 | 01-04-2008 01:44 |
4 locks closed solution - this work for me | gladeo | Sony Ericsson | 11 | 05-21-2003 13:05 |
truim cosmo solution 100% working for exchange | patric | Exchange Section | 0 | 03-16-2002 00:52 |
