12-07-2007, 06:36 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 300690 Status: Offline Thanks Meter: 12 | Need Urgent Help For Sands P908 |
12-07-2007, 07:03 | #3 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 205128 Status: Offline Thanks Meter: 18 | yoh have bad lcd the messgage written in chinese is callibration insruction try fix your touch pad or get another lcd and callibrate before it will work. no need to format any more. |
12-07-2007, 07:14 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Please, follow this instruction and send "backup_flash..." files to [email protected] also pls send "backup_system_log..." files, it's important |
12-07-2007, 09:08 | #9 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | i send a mail which has firmware from " [email protected]" |
12-07-2007, 11:52 | #10 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | when i do complete formate......... COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:AE41:4E98 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: id.55FF3B51.[M438_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN_431C0E76].rpl New firmware detected: M438_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 55FF3B51 identification#1 protocol ver: 04 ver. sw1: M438_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN ver. sw2: MAUI.05C.W06.16.MP.V7 ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: 98004900000002:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom[M438_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[M438_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN]_20071207-162434.B0E.bin flash: 98004900000002:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 98004900000002:29EA0000000000 Write Done file saved: backup_system_log_55FF3B51_M438_26_26_05C_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN_431C0E76_2 0071207-162449.B0X.bin Finished, time used: 384 sec Remove/Install battery now ! |
need pin out for SANDS P908 | apmobileshyd | Infinity-Box | 1 | 01-04-2008 12:46 |
need help for sands p908 | sartaj | Infinity-Box | 2 | 12-06-2007 18:57 |
Need urgent help for SEGAMs. | DrMobile | Phone Unlocking Codes & Maps | 8 | 05-18-2003 12:33 |
needs urgent help for s46 flasher | Dubem | x1x to x45/x50 | 2 | 04-10-2003 18:55 |
Need urgent help for Sagem 992 S5 with 16k eeprom | mr_x4you | Infineon C16X M51 & ARM7 M52 BASED | 6 | 05-02-2002 04:36 |
