10-25-2007, 15:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Panasonic A100 hv problem to UNLOCK - URGENT Device: Panasonic A100,A101,A102 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Err: wrong answer, error#01 Boot Fail Finished Remove/Install battery now ! Time used: 74 sec any1 unlocked this before?? phone shud be off before asking "Press and HOLD Power button !"?? my cable is G5O (B) wat is the problem plz?? Thnx BR khemal |
10-25-2007, 19:46 | #3 (permalink) | |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Quote:
Thx for ur reply im using infinity cable G50 {label "AT106 G50 (B)} via BOX RJ45 Yeah COM PORT is 1, i just unlock a moto c113a... but still can`t get connection wiz my panasonic A100.. Wat is the procedure plz?? or maybe a problem wiz phone itself.. | |
10-25-2007, 20:44 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, now i see com port selected correctly. then only one reason can be: you must cut rubber arround connector. please run shell.exe, select model A100, you will see pinout for this phone click on Picture2, Picture3. you will see how to modify phone connector to make it fit in properly |
10-26-2007, 12:10 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello Red Sun! please run shell.exe, select model A100, you will see pinout for this phone click on Picture2, Picture3. you will see how to modify phone connector to make it fit in properly |
10-26-2007, 17:58 | #8 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Thnx infinity support i unlock it i modified the cable as u said i used G50 cable on rj45 / mbus / com6 phone is done, Thnx infinity Team ))) BR khemal |
06-17-2008, 17:41 | #10 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Colombia Age: 38
Member: 643649 Status: Offline Thanks Meter: 11 | UNLOCK SUCESS A102 CABLE: PAN G50 COM9 [VCP1] selected Device: Panasonic-A100,A101,A102 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E220A2201:80E59F00000000 flash: Amd PL032J D 4Mb id: 00005250 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-1_20080617-113957.03E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 Format file system Done Write... Preparing... area requested/selected: 02/03 Write Done Finished Remove/Install battery now ! Time used: 31 sec |
The Following User Says Thank You to ivanunki For This Useful Post: |
panasonic A100 Mic problem | hooi76 | Hardware Repair by brands | 1 | 02-15-2007 15:51 |
Panasonic A100 Display Problem | gsmsikar | Panasonic | 7 | 08-31-2005 06:00 |
A100 ..very difficult to unlock | tical | Panasonic | 1 | 01-10-2005 16:15 |
panasonic g50 code needed to unlock phone | ~stuie~ | Phone Unlocking Codes & Maps | 6 | 07-11-2004 14:09 |
Panasonic X70 camera problem after unlock? | DanV | Panasonic | 2 | 06-30-2004 13:34 |
