02-23-2009, 12:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Pin finder problem. Tested with many phones. Any solution please. Can we use external power / Battery to phone while using pinfinder instead of RJ45 cable positive and negative wires to power up phones ? |
02-23-2009, 16:52 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
02-23-2009, 17:41 | #3 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
What was happened that PinFinder stop to work ? Please, check voltage value at Unibox (not PinFinder but Unibox) pin-1. What is voltage value ? | |
02-24-2009, 08:29 | #4 (permalink) | |
Member: 54993 Status: Offline Thanks Meter: 47 | Quote:
Nothing special happen to stop pin finder working. | |
02-24-2009, 14:04 | #7 (permalink) |
Member: 54993 Status: Offline Thanks Meter: 47 | Now it seems very much clear. I am using dual RJ45 output unibox, one is mentioned as USB and the other is mentioned as COM. At pin 1 voltage is 4.55 V at USB and 4.9 V at COM sockets. I always connect Pin finder with socket mentioned USB, selector swith kept at M-bus. Is it right way to connect ? The same way I have succesfully connected and flashed / formatted many chinese phones. Do I still need to modify unibox as per Page 20 of Pinfinder manual ? Thanks for great support. |
02-25-2009, 15:04 | #9 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 295357 Status: Offline Thanks Meter: 15 | i have pinfinder use with infinity set not detect it pinfinder show this error software version: 1.17 cable type: 2x6 (L12B) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM4... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 67 sec Power Off ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") plz send it answer [email protected] |
02-25-2009, 19:31 | #10 (permalink) |
Member: 720034 Status: Offline Thanks Meter: 213 | @rajumobile Please, open Unibox and short diode according to manual page 20 @abrarlove Please, see PinFinder manual page-20 and make mall modifications in your L12B cable. |
02-26-2009, 15:55 | #12 (permalink) |
Freak Poster Join Date: Oct 2007 Location: manizales-colombia Age: 35
Member: 621952 Status: Offline Thanks Meter: 15 | i just did google pinfinder+ infinity and look what i found http://www.infinity-box.biz/index.ph...infinder&lg=en theres the manual, BTW if you get a lil bit lost with the short have in mind that those points are from the input port to the output port of your unibox (the "usb" one of course) |
02-26-2009, 15:56 | #13 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | at your service http://www.infinity-box.biz/download..._PinFinder.pdf |
Infinity Pin Finder Problem....?? | srini.unique | Infinity-Box | 5 | 06-11-2008 22:08 |
pin finder problem ... | BoOzer665 | Infinity-Box | 2 | 06-04-2008 21:14 |
Pin Finder Problem Installtion | Mansoor | Infinity-Box | 1 | 05-12-2008 09:44 |
pin finder problem | srini.unique | Infinity-Box | 1 | 03-17-2008 12:14 |
strange pin finder problem | sandeephanda78 | Infinity-Box | 9 | 02-29-2008 11:56 |
