02-12-2008, 14:51 | #19 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:EE41:6B98 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. E:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. E:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22202200:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF flash: 01227E22202200:FFFFFF00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 01227E22202200:FFFFFF00000000 error: error# 0000006F error: flash erase error: 00EC0000 error: error# 0000006F error: flash erase error: 00EC0000 error: error# 0000002B error: flash erase error: 00EC0000 Write Fail Finished, time used: 131 sec Remove/Install battery now ! |
m7500 unlock?? any pinouts for rj45 to phone?? | GospoPL | UST Pro II | 0 | 03-26-2009 17:56 |
Need help I need pinout for this chinese phone | cayton_l | Infinity-Box | 9 | 12-03-2008 19:22 |
neede pinout for lovme china phone | unlocker87 | Chinese Models & Cloned Phones | 0 | 11-04-2008 23:49 |
Here you can find reall pinouts for new Motorola phones (V66,V60...) | VictorGSM | Motorola P2k | 2 | 11-27-2001 22:07 |
